I am trying to use peridynamics for crack simulation in lammps. I have
a questions:
I use the acrylic glass mechanical material for simulation, but the cracks do not grow from pre-crack. I got the force from the test results.
Is the potential not correct or there is another code error?
Thanks for your help
leila abbasiThis is my file:
# 2d crack
units si
dimension 2
boundary s s p
atom_style peri
atom_modify map array
neighbor 0.0002 bin
# create geometry
lattice sq 0.0001
region plate block -0.0065 0.0065 -0.0285 0.0285 -0.004 0.004 units box
create_box 7 plate
create_atoms 1 region plate
region crack block -0.0065 0 0 0.000001 -0.004 0.004 units box
group crack region crack
delete_atoms group crack
pair_style peri/pmb
pair_coeff * * 2.94138e24 0.000301 0.038614 0.22
pair_coeff 4 5 2.94138e24 0 0.038614 0
pair_coeff 2 * 2.94138e24 0.0003001 1 0
pair_coeff 7 * 2.94138e24 0.0003001 1 0
set group all density 1180
set group all volume 25e-8
velocity all set 0.0 0.0 0.0 sum no units box
region 2 block INF INF INF -0.028199 INF INF units box
group A region 2
region 3 block INF INF -0.028199 -0.027898 INF INF units box
group B region 3
region 4 block INF INF -0.027898 0 INF INF units box
group low region 4
region 5 block INF INF 0.000001 0.027898 INF INF units box
group up region 5
region 6 block INF INF 0.027898 0.028199 INF INF units box
group E region 6
region 7 block INF INF 0.028199 0.0285 INF INF units box
group F region 7
set group A type 2
set group B type 3
set group low type 4
set group up type 5
set group E type 6
set group F type 7
fix 1 all nve
fix 7 F addforce 0 2.943e15 0
fix 2 A addforce 0 -2.943e15 0
compute 1 all damage/atom
timestep 3e-8
thermo 20
dump 1 all custom 20 dump.lammpstrj id x y z c_1
dump 2 all xyz 20 dump.xyz
run 200
