Am attempting to load a data file using read_data (written with write_data) on one machine which was written on another. LAMMPS crashes w no message. Both LAMMPS builds are 1 Feb 14. One is “xe6”. The other is “chama”. The pair coeffs were written by write_data. The only difference I can see is that the “MPI core grid” may well be different among the machine that wrote the file and the one which is reading it. Any thoughts?
Regards,
J. Moller
Both LAMMPS builds are 1 Feb 14. One is "xe6". The other is "chama". The
version 1 Feb14 is way outdated.
try to recreate this with the latest LAMMPS version and if the issue
persists, you need to provide us with a test case (as small as
possible, please). so that it can be properly debugged and checked.
