Dear all
I try to build a simulation box mixing 1 atome type and a mole cule
I write.
molecule Gly glycerol_753.txt
region mybox block 0 50 0 50 0 30
create_box 4 mybox
create_atoms 4 random 50 78913542 mybox overlap 3.0 maxtry 50
create_atoms offset mol Gly random 5 24897364 mybox overlap 3.0 maxtry 50
I read in the manual:
- type = atom type (1-Ntypes) of atoms to create (offset for molecule creation)
so I used offset as type
But I got the following error, meaning aan integer is required for type ?:
D:\MD\Pt-Glycerol> lmp -in Pt-Gly_GAS.in
LAMMPS (28 Mar 2023 - Development)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
Loaded 1 plugins from C:\Users\pascal.brault\AppData\Local\LAMMPS 64-bit 2023-04-10-MSMPI\plugins
Loaded 1 plugins from C:\Users\pascal.brault\AppData\Local\LAMMPS USER-REBOMOS Plugin 28Mar2023-MSMPI
Loaded 1 plugins from C:\Users\pascal.brault\AppData\Local\LAMMPS ML-PACE Plugin 28Mar2023-MSMPI
Loaded 1 plugins from C:\Users\pascal.brault\AppData\Local\LAMMPS USER-AEAM Plugin 28Mar2023-MSMPI
units real
atom_style charge
log logPtGlynvt.lammps
Read molecule template Gly:
1 molecules
0 fragments
14 atoms with max type 3
0 bonds with max type 0
0 angles with max type 0
0 dihedrals with max type 0
0 impropers with max type 0
create_box 4 mybox
Created orthogonal box = (0 0 0) to (50 50 30)
Created 50 atoms
using lattice units in orthogonal box = (0 0 0) to (50 50 30)
create_atoms CPU = 0.001 seconds
ERROR: Expected integer parameter instead of ‘offset’ in input script or data file (src/create_atoms.cpp:92)
Last command: create_atoms offset mol Gly random 5 24897364 mybox overlap 3.0 maxtry 50
PS D:\MD\Pt-Glycerol>
I do not find what is wrong in my script ?
Thanks a lot in advance
Pascal
