I’m currently working on the following script to generate the CIF files (which uses the cig_gen converter):
from optimade.adapters.structures.utils import (
cell_to_cellpar,
fractional_coordinates,
valid_lattice_vector,
from optimade.models import Species as OptimadeStructureSpecies
from optimade.models import StructureResource as OptimadeStructure
import os
import pickle
import argparse
import pandas as pd
import requests
from tqdm import tqdm
from pymatgen.ext.optimade import OptimadeRester
try:
import numpy as np
except ImportError:
from warnings import warn
from optimade.adapters.warnings import AdapterPackageNotFound
np = None # type: ignore[assignment]
NUMPY_NOT_FOUND = "NumPy not found, cannot convert structure to CIF"
__all__ = ("get_cif",)
# API Endpoints dictionary
api_endpoints = {
'aflow': 'https://aflow.org/API/optimade/',
'alexandria': 'https://alexandria.icams.rub.de/pbe/',
'alexandria.pbe': 'https://alexandria.icams.rub.de/pbe/',
'alexandria.pbesol': 'https://alexandria.icams.rub.de/pbesol/',
'cod': 'https://www.crystallography.net/cod/optimade/',
'cmr': 'https://cmr-optimade.fysik.dtu.dk/',
'mcloud.mc3d': 'https://aiida.materialscloud.org/mc3d/optimade/',
'mcloud.mc2d': 'https://aiida.materialscloud.org/mc2d/optimade/',
'mcloud.2dtopo': 'https://aiida.materialscloud.org/2dtopo/optimade/',
'mcloud.tc-applicability': 'https://aiida.materialscloud.org/tc-applicability/optimade/',
'mcloud.pyrene-mofs': 'https://aiida.materialscloud.org/pyrene-mofs/optimade/',
'mcloud.curated-cofs': 'https://aiida.materialscloud.org/curated-cofs/optimade/',
'mcloud.stoceriaitf': 'https://aiida.materialscloud.org/stoceriaitf/optimade/',
'mcloud.scdm': 'https://aiida.materialscloud.org/autowannier/optimade/',
'mcloud.tin-antimony-sulfoiodide': 'https://aiida.materialscloud.org/tin-antimony-sulfoiodide/optimade/',
'mcloud.optimade-sample': 'https://aiida.materialscloud.org/optimade-sample/optimade/',
'mp': 'https://optimade.materialsproject.org/',
'mpdd': 'http://mpddoptimade.phaseslab.org/',
'mpds': 'https://api.mpds.io/',
'nmd': 'https://nomad-lab.eu/prod/rae/optimade/',
'odbx': 'https://optimade.odbx.science/',
'odbx.odbx_misc': 'https://optimade-misc.odbx.science/',
'odbx.gnome': 'https://optimade-gnome.odbx.science/',
'omdb.omdb_production': 'https://optimade.openmaterialsdb.se/',
'oqmd': 'https://oqmd.org/optimade/',
'jarvis': 'https://jarvis.nist.gov/optimade/jarvisdft/',
'tcod': 'https://www.crystallography.net/tcod/optimade/',
'twodmatpedia': 'http://optimade.2dmatpedia.org/'
def fetch_structures(api_name, base_url, page_limit=1):
structures = []
endpoint = f"{base_url}/structures"
params = {'page_limit': page_limit}
try:
response = requests.get(endpoint, params=params)
response.raise_for_status()
data = response.json()
structures = data.get("data", [])
except requests.exceptions.RequestException as e:
print(f"Error fetching structures from {api_name}: {e}")
return structures
def get_cif(
optimade_structure: OptimadeStructure,
) -> str:
"""Get CIF file as string from OPTIMADE structure.
Parameters:
optimade_structure: OPTIMADE structure.
Returns:
The CIF file as a single Python `str` object.
# NumPy is needed for calculations
if globals().get("np", None) is None:
warn(NUMPY_NOT_FOUND, AdapterPackageNotFound)
return None # type: ignore[return-value]
cif = """#
# Created from an OPTIMADE structure.
cif += f"data_{optimade_structure.id}\n\n"
attributes = optimade_structure.attributes
# Do this only if there's three non-zero lattice vectors
# NOTE: This also negates handling of lattice_vectors with null/None values
if valid_lattice_vector(attributes.lattice_vectors): # type:ignore[arg-type]
a_vector, b_vector, c_vector, alpha, beta, gamma = cell_to_cellpar(
attributes.lattice_vectors # type: ignore[arg-type]
cif += (
f"_cell_length_a {a_vector:g}\n"
f"_cell_length_b {b_vector:g}\n"
f"_cell_length_c {c_vector:g}\n"
f"_cell_angle_alpha {alpha:g}\n"
f"_cell_angle_beta {beta:g}\n"
f"_cell_angle_gamma {gamma:g}\n\n"
cif += (
"_symmetry_space_group_name_H-M 'P 1'\n"
"_symmetry_int_tables_number 1\n\n"
"loop_\n"
" _symmetry_equiv_pos_as_xyz\n"
" 'x, y, z'\n\n"
# Since some structure viewers are having issues with cartesian coordinates,
# we calculate the fractional coordinates if this is a 3D structure and we have all the necessary information.
if not hasattr(attributes, "fractional_site_positions"):
attributes.fractional_site_positions = fractional_coordinates(
cell=attributes.lattice_vectors, # type:ignore[arg-type]
cartesian_positions=attributes.cartesian_site_positions, # type:ignore[arg-type]
# NOTE: This is otherwise a bit ahead of its time, since this OPTIMADE property is part of an open PR.
# See https://github.com/Materials-Consortia/OPTIMADE/pull/206
coord_type = (
"fract" if hasattr(attributes, "fractional_site_positions") else "Cartn"
cif += (
"loop_\n"
" _atom_site_type_symbol\n" # species.chemical_symbols
" _atom_site_label\n" # species.name + unique int
" _atom_site_occupancy\n" # species.concentration
f" _atom_site_{coord_type}_x\n" # cartesian_site_positions
f" _atom_site_{coord_type}_y\n" # cartesian_site_positions
f" _atom_site_{coord_type}_z\n" # cartesian_site_positions
" _atom_site_thermal_displace_type\n" # Set to 'Biso'
" _atom_site_B_iso_or_equiv\n" # Set to 1.0:f
if coord_type == "fract":
sites = attributes.fractional_site_positions
else:
sites = attributes.cartesian_site_positions
species: dict[str, OptimadeStructureSpecies] = {
species.name: species
for species in attributes.species # type: ignore[union-attr]
symbol_occurences: dict[str, int] = {}
for site_number in range(attributes.nsites): # type: ignore[arg-type]
species_name = attributes.species_at_sites[site_number] # type: ignore[index]
site = sites[site_number]
current_species = species[species_name]
for index, symbol in enumerate(current_species.chemical_symbols):
if symbol == "vacancy":
continue
if symbol in symbol_occurences:
symbol_occurences[symbol] += 1
else:
symbol_occurences[symbol] = 1
label = f"{symbol}{symbol_occurences[symbol]}"
cif += (
f" {symbol} {label} {current_species.concentration[index]:6.4f} {site[0]:8.5f} "
f"{site[1]:8.5f} {site[2]:8.5f} {'Biso':4} {'1.000':6}\n"
return cif
def save_cif(cif_text, output_dir, structure_id):
if not os.path.exists(output_dir):
os.makedirs(output_dir)
file_path = os.path.join(output_dir, f"{structure_id}.cif")
try:
with open(file_path, 'w') as f:
f.write(cif_text)
except Exception as e:
print(f"Error saving CIF for structure {structure_id}: {e}")
def compile_metadata(metadata_table, reduced_formula, database_name, cif_text):
metadata_table.append({
'reduced_formula': reduced_formula,
'database': database_name,
'cif_text': cif_text
def save_pickle(metadata_table, filename):
df = pd.DataFrame(metadata_table)
if os.path.exists(filename):
# Load existing data and append
with open(filename, 'rb') as f:
existing_df = pickle.load(f)
df = pd.concat([existing_df, df], ignore_index=True)
try:
with open(filename, 'wb') as f:
pickle.dump(df, f)
print(f"Metadata successfully saved to {filename}")
print(f"Error saving pickle file: {e}")
def main():
parser = argparse.ArgumentParser(description="Fetch structures from OPTIMADE databases and convert to CIF.")
parser.add_argument('--database', nargs='+', required=True, help="List of databases to fetch data from.")
parser.add_argument('--dataset', type=int, required=True, help="Number of entries to fetch from each database.")
parser.add_argument('--output_dir', required=True, help="Directory to save CIF files and metadata pickle file.")
args = parser.parse_args()
output_cif_dir = os.path.join(args.output_dir, 'cif_files')
output_pkl_file = os.path.join(args.output_dir, 'structures_metadata.pkl')
metadata_table = []
for db in args.database:
if db not in api_endpoints:
print(f"Database '{db}' not recognized. Skipping.")
continue
base_url = api_endpoints[db]
print(f"Fetching structures from {db}...")
structures = fetch_structures(db, base_url, page_limit=args.dataset)
print(f"Number of structures fetched from {db}: {len(structures)}")
for structure_dict in tqdm(structures, desc=f"Processing {db}", leave=False):
try:
structure = StructureResource(**structure_dict)
print(f"Error parsing structure: {e}")
continue
structure_id = structure.id
attributes = structure.attributes
reduced_formula = attributes.chemical_formula_reduced or 'N/A'
try:
cif_text = get_cif(structure)
print(f"Error generating CIF for structure {structure_id}: {e}")
cif_text = None
if cif_text:
try:
save_cif(cif_text, output_cif_dir, structure_id)
compile_metadata(metadata_table, reduced_formula, db, cif_text)
print(f"Error saving CIF or compiling metadata for structure {structure_id}: {e}")
else:
print(f"Skipping structure {structure_id} due to conversion issues.")
# Save all metadata to a pickle file
try:
save_pickle(metadata_table, output_pkl_file)
print(f"Error saving metadata: {e}")
if __name__ == "__main__":
main()
My issue is that it works for some databases (so far alexandria), but others like Jarvis I get errors like:
- Sometimes the script works, sometimes it does not connect to the databases, and sometimes there is insufficient information to generate the CIF files
- This morning for example I cant connect even though yesterday it was working
Error fetching structures from jarvis: HTTPSConnectionPool(host=‘jarvis.nist.gov’, port=443): Max retries exceeded with url: /optimade/jarvisdft//structures?page_limit=50 (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0x7f4d752707d0>: Failed to establish a new connection: [Errno 101] Network is unreachable’))
Thanks for the help!
