I am trying to create two neighbor lists to iterate over: intermolecular (atoms not in the same molecule) and intramolecular (atoms in the same molecule). These neighbor lists are defined at a timestep = 0. These two lists will accessed every couple of timesteps during the simulation. I was wondering if there is a “LAMMPS-appropriate” way to construct these lists. Also, I have tried to browse all the various compute functions in LAMMPS, but I can not find a good example. Currently, I am using list<list> for the lists of list and list as a singular list. Please see below a code snippet where I construct these neighbor lists:
if (firstflag) {
nchunk = n; //this is a chunk compute
allocate(); //Memory allocation due a chunk compute
size_array_rows = nchunk;
if (nl_need) {
neighbor->build_one(list); //Building a neighbor list
std::list<int> sgl_lst; //list construction
inum = list->inum; // # of I atoms neighbors are stored for
ilist = list->ilist; // local indices of I atoms
numneigh = list->numneigh; //number of neighbors
firstneigh = list->firstneigh; // ptr to 1st J int value of each I atom
int **bondlist = neighbor->bondlist; // list of bonded neighbors
int nbondlist = neighbor->nbondlist; //number of bonded neighbors
for (ii = 0; ii < inum; ii++) {
i = ilist[ii]; //picking an atom
if (mask[i] & groupbit) {
xtmp = x[i][0]; //positions
ytmp = x[i][1];
ztmp = x[i][2];
jlist_er = firstneigh[i];
jnum_er = numneigh[i];
int ncount_ra = 0;
for (jj_ra = 0; jj_ra < nbondlist; jj_ra++) {
j_ra = bondlist[i][1];
j_ra &= NEIGHMASK;
sgl_lst.push_back(j_ra); //appending atom index to list
ncount_ra++;
n_intra_neigh->push_back(ncount_ra);
ra_list.push_back(sgl_lst);
std::unordered_set<int> set_neigh(sgl_lst.begin(), sgl_lst.end()); //defining a set
sgl_lst.clear(); //clearing list to prepare for intermolecular list
int ncount_er = 0;
for (jj = 0; jj < jnum_er; jj++) {
j_er = jlist_er[jj];
if (set_neigh.find(j) != set_neigh.end()) { //if atom index is not in intra_list then it is in inter_list
j &= NEIGHMASK;
delx = xtmp - x[j][0];
dely = ytmp - x[j][1];
delz = ztmp - x[j][2];
rsq = delx * delx + dely * dely + delz * delz;
if (rsq < cutsq ) { //radial cutoff to define intermolecular neighbor list
sgl_lst.push_back(j_er);
ncount_er++;
n_inter_neigh->push_back(ncount_er);
er_list.push_back(sgl_lst);
Also, in the header file:
std::list<std::list> ra_list, er_list;
std::vector *n_inter_neigh, *n_intra_neigh;
