Dear all:
I’m trying to compile GPU acceletated lammps for dpd simulation. I have tried many methods, but the compiled lammps program cannot start the dpd simulation normally.The following is the compilation process, I hope this information can help us solve the problem.
nvidia-smi
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce 2060 Off | 00000000:01:00.0 Off | N/A |
| 35% 37C P0 1W / 170W | 0MiB / 6144MiB | 0% Default |
| | | N/A |
nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Jun__8_16:49:14_PDT_2022
Cuda compilation tools, release 11.7, V11.7.99
Build cuda_11.7.r11.7/compiler.31442593_0
cmake -D PKG_GPU=on -D GPU_API=cuda -D GPU_PREC=mixed -D GPU_ARCH=sm_75 -D CUDPP_OPT=yes -D PKG_DPD-BASIC=on -D PKG_MOLECULE=on -D PKG_EXTRA-FIX=on -D CMAKE_INSTALL_PREFIX=/home/sfj/software/lammps/.local ../cmake
in lammps-23Jun2022/build, print:
-- The CXX compiler identification is GNU 11.4.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Git: /usr/bin/git (found version "2.34.1")
-- Running check for auto-generated files from make-based build system
-- Found MPI_CXX: /usr/lib/x86_64-linux-gnu/libmpichcxx.so (found version "4.0")
-- Found MPI: TRUE (found version "4.0")
-- Looking for C++ include omp.h
-- Looking for C++ include omp.h - found
-- Found OpenMP_CXX: -fopenmp (found version "4.5")
-- Found OpenMP: TRUE (found version "4.5") found components: CXX
-- Found GZIP: /usr/bin/gzip
-- Found FFMPEG: /usr/bin/ffmpeg
-- Looking for C++ include cmath
-- Looking for C++ include cmath - found
-- Looking for C++ include pthread.h
-- Looking for C++ include pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found CUDA: /usr/local/cuda-11.7 (found version "11.7")
-- Generating style headers...
-- Generating package headers...
-- Generating lmpinstalledpkgs.h...
-- Found ClangFormat: /usr/bin/clang-format (found suitable version "14.0.0", minimum required is "8.0")
-- The following tools and libraries have been found and configured:
* Git
* MPI
* Threads
* CUDA
* OpenMP
* ClangFormat (required version >= 8.0)
-- <<< Build configuration >>>
LAMMPS Version: 20220623
Operating System: Linux Ubuntu 22.04
CMake Version: 3.22.1
Build type: RelWithDebInfo
Install path: /home/sfj/software/lammps/.local
Generator: Unix Makefiles using /usr/bin/gmake
-- Enabled packages: DPD-BASIC;EXTRA-FIX;GPU;MOLECULE
-- <<< Compilers and Flags: >>>
-- C++ Compiler: /usr/bin/c++
Type: GNU
Version: 11.4.0
C++ Flags: -O2 -g -DNDEBUG
Defines: LAMMPS_SMALLBIG;LAMMPS_MEMALIGN=64;LAMMPS_OMP_COMPAT=4;LAMMPS_GZIP;LAMMPS_FFMPEG;LMP_GPU
-- <<< Linker flags: >>>
-- Executable name: lmp
-- Static library flags:
-- <<< MPI flags >>>
-- MPI_defines: MPICH_SKIP_MPICXX;OMPI_SKIP_MPICXX;_MPICC_H
-- MPI includes: /usr/include/x86_64-linux-gnu/mpich
-- MPI libraries: /usr/lib/x86_64-linux-gnu/libmpichcxx.so;/usr/lib/x86_64-linux-gnu/libmpich.so;
-- <<< GPU package settings >>>
-- GPU API: CUDA
-- CUDA Compiler: /usr/local/cuda-11.7/bin/nvcc
-- GPU default architecture: sm_75
-- GPU binning with CUDPP: yes
-- CUDA MPS support: OFF
-- GPU precision: MIXED
-- Configuring done
-- Generating done
-- Build files have been written to: /home/sfj/870_QVO/Download/lammps-23Jun2022/build
make -j 16
It can be compiled normally, and two warning messages are returned:
[ 87%] Building CXX object CMakeFiles/lammps.dir/home/sfj/870_QVO/Download/lammps-23Jun2022/src/write_restart.cpp.o
/home/sfj/870_QVO/Download/lammps-23Jun2022/src/variable.cpp: In member function ‘int LAMMPS_NS::Variable::next(int, char**)’:
/home/sfj/870_QVO/Download/lammps-23Jun2022/src/variable.cpp:744:14: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’ declared with attribute ‘warn_unused_result’ [-Wunused-result]
744 | fread(buf,1,64,fp);
[100%] Linking CXX executable lmp
lto-wrapper: warning: using serial compilation of 128 LTRANS jobs
make install
cd ../examples/PACKAGES/dpd-basic/dpd
mpirun -np 8 lmp -in in.dpd -sf gpu
error:
Generated 0 of 1 mixed pair_coeff terms from geometric mixing rule
Setting up Verlet run ...
Unit style : lj
Current step : 0
Time step : 0.01
Cuda driver error 700 in call at file '/home/sfj/870_QVO/Download/lammps-23Jun2022/lib/gpu/geryon/nvd_timer.h' in line 76.
Abort(-1) on node 7 (rank 7 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, -1) - process 7
When I use GPU_API=opencl instead of GPU_API=CUDA :
cmake -D PKG_GPU=on -D GPU_API=opencl -D PKG_DPD-BASIC=on -D PKG_MOLECULE=on -D PKG_EXTRA-FIX=on -D CMAKE_INSTALL_PREFIX=/home/sfj/software/lammps/.local ../cmake
-- Downloading and building OpenCL loader library
-- Downloading https://download.lammps.org/thirdparty/opencl-loader-2022.01.04.tar.gz
-- [download 12% complete]
-- [download 25% complete]
-- [download 37% complete]
-- [download 50% complete]
-- [download 63% complete]
-- [download 75% complete]
-- [download 88% complete]
-- [download 100% complete]
-- Unpacking and configuring opencl-loader-2022.01.04.tar.gz
-- The C compiler identification is GNU 11.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for secure_getenv
-- Looking for secure_getenv - found
-- Looking for __secure_getenv
-- Looking for __secure_getenv - not found
* Git
* MPI
* Threads
* OpenMP
Type: GNU
Version: 11.4.0
-- C compiler: /usr/bin/cc
Type:
Version:
C Flags: -O2 -g -DNDEBUG
-- GPU API: OPENCL
-- Configuring done
-- Generating done
make -j 16
waring:
[ 87%] Building CXX object CMakeFiles/lammps.dir/home/sfj/870_QVO/Download/lammps-23Jun2022/src/DPD-BASIC/pair_dpd.cpp.o
make install
errors:
Unit style : lj
Current step : 0
Time step : 0.01
OpenCL error in file '/home/sfj/870_QVO/Download/lammps-23Jun2022/lib/gpu/geryon/ocl_timer.h' in line 92 : -9999.
Abort(-1) on node 3 (rank 3 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
I also tried different versions of nvidia driver and cuda, but the same error occurred. Forgive me for not documenting the full details of the attempt. Another information that may be available is: Earlier, I successfully compiled cuda-accelerated gromacs. The gromacs manual is different from the lammps manual. It gives information about the best compilation environment. This may be the reason why I successfully compiled gromacs but failed to compile lammps.
Finally, thanks to everyone who provided technical help on the lammps forum.
