Hi
it seems the line "kspace_modify order 7" is causing a problem. If you let the thermo output be calculated every step you will see that using that line causes NANs, at which point the simulation stops to proceed. I'll try to figure out what the actual problem is, but until then just outcommenting that line solves the problem.
Cheers
Christian
-------- Original-Nachricht --------
