Hello, everyone.
Previously, I asked about ways to extract cohesive energy from the API,
and thankfully, several developers in this group added such functionality.
Previous question, cohesive energy
However, through various attempts, I discovered that the cohesive values obtained through the API differ from the cohesive values calculated directly and those known from experimental data.
Could this difference be due to the R2SCAN result, possibly an error caused by the difference in calculation methods?
I’m more confused because I’m not sure whether the value obtained through the code is the PBE calculation result or the R2SCAN calculation result.
Firstly, the code I used to obtain the cohesive values is as follows below.
# Get Cohesive energy
cohesive_energy = mpr.get_cohesive_energy(
material_ids=[material_id], normalization="atom" # normalize with number of atom
)[material_id] # results are returned into dictionary
| Alloy | Total E | Iso E | # | Cohesive [Ry/atm] | Cohesive [eV/atm] | API | API. vs Cal. | Exp. vs Cal. | Exp. |
| Ac4_mp-862690 | -3750.991527 | -937.465441 | 4 | -0.282440802 | -3.84280595 | -3.551579413 | -0.291226537 | 0.40719405 | 4.25 |
| Ag4_mp-8566 | -1421.20241 | -355.1146236 | 4 | -0.185978743 | -2.530371716 | -2.877377145 | 0.347005429 | 0.419628284 | 2.95 |
| Al1_mp-134 | -39.50252869 | -39.24457782 | 1 | -0.25795087 | -3.509603178 | -3.59590833 | 0.086305152 | -0.119603178 | 3.39 |
| Ar1_mp-23155 | -95.08174323 | 1 | #N/A | #N/A | #N/A | #N/A | 0.08 | ||
| As4_mp-158 | -703.9567663 | -175.7727037 | 4 | -0.216487845 | -2.945469533 | -2.871830988 | -0.073638546 | 0.014530467 | 2.96 |
| Au1_mp-81 | -775.1387284 | -774.9162859 | 1 | -0.22244248 | -3.026486535 | -3.40956015 | 0.383073615 | 0.783513465 | 3.81 |
| Ba1_mp-122 | -436.1810481 | -436.0425076 | 1 | -0.13854048 | -1.88494076 | -1.98923344 | 0.10429268 | 0.01505924 | 1.9 |
| Be2_mp-87 | -13.63807385 | -6.37132664 | 2 | -0.447710285 | -6.091413605 | -3.781196417 | -2.310217187 | -2.771413605 | 3.32 |
| Bi2_mp-23152 | -1812.73081 | -906.1800103 | 2 | -0.18539483 | -2.522427176 | -2.302373745 | -0.220053431 | -0.342427176 | 2.18 |
Of course, there are many cases where the values I calculated differ from the experimental ones, but I’m not sure why such differences occur. I suspect that it might be influenced by whether optimization is involved or not.
Thank you.
Sincerely.
