Dear Anubhav,
Thanks a lot! Now qlaunch is working and relaxation step is done but it stops after optimization. When I used qlaunch rapidfire , I also got these warning below:
/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/queue/queue_adapter.py:143: UserWarning: Key rocket_launch has been specified in qadapter but it is not present in template, please check template (/scratch/users/skumar/atomate_opt/config/job_ht.sh) for supported keys.
.format(subs_key, self.template_file))
/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/queue/queue_adapter.py:143: UserWarning: Key nodes has been specified in qadapter but it is not present in template, please check template (/scratch/users/skumar/atomate_opt/config/job_ht.sh) for supported keys.
/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/queue/queue_adapter.py:143: UserWarning: Key ntasks_per_node has been specified in qadapter but it is not present in template, please check template (/scratch/users/skumar/atomate_opt/config/job_ht.sh) for supported keys.
/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/queue/queue_adapter.py:143: UserWarning: Key walltime has been specified in qadapter but it is not present in template, please check template (/scratch/users/skumar/atomate_opt/config/job_ht.sh) for supported keys.
################### slurm.out##############################
== Starting run at Sat Aug 10 11:46:06 CEST 2019
== Job ID: 682351
== Node list: iris-131
== Submit dir. : /mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357
Error reading item ‘VCAIMAGES’ from file INCAR.
2019-08-10 11:46:09,017 INFO Hostname/IP lookup (this will take a few seconds)
2019-08-10 11:46:12,788 INFO Created new dir /mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357/launcher_2019-08-10-09-46-12-788389
2019-08-10 11:46:12,789 INFO Launching Rocket
2019-08-10 11:46:14,744 INFO RUNNING fw_id: 4 in directory: /mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357/launcher_2019-08-10-09-46-12-788389
2019-08-10 11:46:15,970 INFO Task started: FileWriteTask.
2019-08-10 11:46:15,971 INFO Task completed: FileWriteTask
2019-08-10 11:46:16,214 INFO Task started: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}.
2019-08-10 11:46:16,297 INFO Task completed: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}
2019-08-10 11:46:16,539 INFO Task started: {{atomate.vasp.firetasks.run_calc.RunVaspCustodian}}.
2019-08-10 11:46:48,138 INFO Task completed: {{atomate.vasp.firetasks.run_calc.RunVaspCustodian}}
2019-08-10 11:46:48,386 INFO Task started: {{atomate.common.firetasks.glue_tasks.PassCalcLocs}}.
2019-08-10 11:46:48,388 INFO Task completed: {{atomate.common.firetasks.glue_tasks.PassCalcLocs}}
2019-08-10 11:46:48,633 INFO Task started: {{atomate.vasp.firetasks.parse_outputs.VaspToDb}}.
2019-08-10 11:46:48,633 INFO atomate.vasp.firetasks.parse_outputs PARSING DIRECTORY: /mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357/launcher_2019-08-10-09-46-12-788389
2019-08-10 11:46:48,633 INFO atomate.vasp.drones Getting task doc for base dir :/mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357/launcher_2019-08-10-09-46-12-788389
2019-08-10 11:46:48,942 INFO atomate.vasp.drones Post-processing dir:/mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357/launcher_2019-08-10-09-46-12-788389
2019-08-10 11:46:48,943 WARNING atomate.vasp.drones Transformations file does not exist.
2019-08-10 11:46:48,984 INFO atomate.vasp.drones Post-processed /mnt/lscratch/users/skumar/atomate_opt/MgO/block_2019-08-10-09-45-44-609779/launcher_2019-08-10-09-45-48-345357/launcher_2019-08-10-09-46-12-788389
2019-08-10 11:46:51,067 INFO Rocket finished
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/site-packages/fireworks/core/rocket.py”, line 262, in run
m_action = t.run_task(my_spec)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/site-packages/atomate/vasp/firetasks/parse_outputs.py”, line 113, in run_task
mmdb = VaspCalcDb.from_db_file(db_file, admin=True)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/site-packages/atomate/utils/database.py”, line 114, in from_db_file
creds = loadfn(db_file)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/site-packages/monty/serialization.py”, line 83, in loadfn
return json.load(fp, *args, **kwargs)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/json/init.py”, line 296, in load
parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/json/init.py”, line 361, in loads
return cls(**kw).decode(s)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/site-packages/monty/json.py”, line 255, in decode
d = json.JSONDecoder.decode(self, s)
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/home/users/skumar/anaconda3/envs/my_env/lib/python3.7/json/decoder.py”, line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting ‘,’ delimiter: line 9 column 3 (char 219)
For your kind information, below are my_qadapter.yaml and job_ht.sh file:
my_qadapter.yaml::::::::::::::::::
_fw_name: CommonAdapter
_fw_q_type: SLURM
_fw_template_file: /scratch/users/skumar/atomate_opt/config/job_ht.sh
rocket_launch: rlaunch -c /scratch/users/skumar/atomate_opt/config rapidfire
nodes: 1
ntasks_per_node: 28
walltime: 05:00:00
queue: null
account: null
job_name: null
pre_rocket: null
post_rocket: null
logdir: /scratch/users/skumar/atomate_opt/logs
job_ht.sh
#!/bin/bash -l
Submission script for Iris
#SBATCH -J HTS
#SBATCH --mail-type=end,fail
#SBATCH [email protected]
#SBATCH -N 1
#SBATCH --ntasks-per-node=28
#SBATCH -c 1
#SBATCH --time=0-05:00:00
#SBATCH -p batch
#SBATCH --qos=qos-batch
####SBATCH --qos=qos-besteffort
#print
echo “== Starting run at $(date)”
echo “== Job ID: ${SLURM_JOBID}”
echo “== Node list: ${SLURM_NODELIST}”
echo “== Submit dir. : ${SLURM_SUBMIT_DIR}”
Set up the python environment
Set up the linux environment, i.e. load the modules you need to run VASP
#module load swenv/default-env/devel
module load phys/VASP/5.4.4-intel-2018a
####srun -n $SLURM_NTASKS vasp_ncl
srun -n $SLURM_NTASKS vasp_std
Run the rlaunch command
Could you please tell me where I did a mistake ? I would be very thankful to you.
Thanks and regards
Sandeep
On Saturday, August 10, 2019 at 12:54:22 AM UTC+2, Anubhav Jain wrote:
Your my_qadapter.yaml should say “_fw_name: CommonAdapter” not “fw_name: CommonAdapter”
On Tuesday, August 6, 2019 at 10:28:35 AM UTC-7, Sandeep wrote:
Dear Anubhav,
Thank you very much for your reply. Actually, VASP run through a job scheduler like SLURM . So I think I should use qlaunch instead of rlaunch and for this, I set up my_qadapter.yaml file and the contain inside are below:
my_qadapter.yaml
_fw_q_type: SLURM
_fw_template_file: /scratch/users/skumar/atomate_opt/job_ht.sh
rocket_launch: qlaunch -c /scratch/users/skumar/atomate_opt/config rapidfire
nodes: 2
walltime: 24:00:00
queue: batch
account: null
job_name: null
pre_rocket: null
post_rocket: null
db.json
"host": "mongodb+srv://[cluster0-aagd1.mongodb.net/](http://cluster0-aagd1.mongodb.net/)",
"port": 27017,
"database": "test",
"collection": "test",
"admin_user": "test",
"admin_password": "12345",
"authsource": "admin"
"aliases": {}
But when I used qlaunch singleshot, I got an error below:
File “/home/users/skumar/anaconda3/envs/atomate_opt/bin/qlaunch”, line 10, in
sys.exit(qlaunch())
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/scripts/qlaunch_run.py”, line 222, in qlaunch
do_launch(args)
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/scripts/qlaunch_run.py”, line 61, in do_launch
queueadapter = load_object_from_file(args.queueadapter_file)
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/utilities/fw_serializers.py”, line 394, in load_object_from_file
return load_object(m_dict)
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/utilities/fw_serializers.py”, line 323, in load_object
fw_name = FW_NAME_UPDATES.get(obj_dict['_fw_name'], obj_dict['_fw_name'])
KeyError: ‘_fw_name’
However, I got VASP input files like INCAR, POTCAR, KPOINTS and POSCAR when I used rlaunch singleshot with an error. And it was like below:
2019-08-06 19:07:47,701 INFO Hostname/IP lookup (this will take a few seconds)
2019-08-06 19:07:47,702 INFO Launching Rocket
2019-08-06 19:07:52,654 INFO RUNNING fw_id: 4 in directory: /mnt/lscratch/users/skumar/atomate_opt/MgO
2019-08-06 19:07:53,886 INFO Task started: FileWriteTask.
2019-08-06 19:07:53,891 INFO Task completed: FileWriteTask
2019-08-06 19:07:54,137 INFO Task started: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}.
2019-08-06 19:07:54,211 INFO Task completed: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}
2019-08-06 19:07:54,456 INFO Task started: {{atomate.vasp.firetasks.run_calc.RunVaspCustodian}}.
Validation failed: <custodian.vasp.validators.VasprunXMLValidator object at 0x7f58d1ededa0>
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/fireworks/core/rocket.py”, line 262, in run
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/atomate/vasp/firetasks/run_calc.py”, line 205, in run_task
c.run()
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/custodian/custodian.py”, line 328, in run
self._run_job(job_n, job)
File “/home/users/skumar/anaconda3/envs/atomate_opt/lib/python3.7/site-packages/custodian/custodian.py”, line 452, in _run_job
raise ValidationError(s, True, v)
custodian.custodian.ValidationError: Validation failed: <custodian.vasp.validators.VasprunXMLValidator object at 0x7f58d1ededa0>
2019-08-06 19:08:16,703 INFO Rocket finished
Could you please suggest me what should I do ? I need your valuable suggestion to resolve this error.
Thanks and regards
Sandeep
On Tuesday, August 6, 2019 at 6:42:36 PM UTC+2, Anubhav Jain wrote:
Hi Sandeep
If you run “rlaunch singleshot”, it will run the workflow on your local system. This means that VASP will also be executed on your local system. I’d first make sure VASP is properly installed on your system.
If you feel that is the case, can you provide more details? For example, does the VASP run start at all? If so, what are the contents of the OUTCAR? Also, what does FW_job.error and FW_job.out say?
Anubhav
On Friday, August 2, 2019 at 10:03:39 AM UTC-7, Sandeep wrote:
I am a new user for atomate. After installation, I tried to launch calculations (example of MgO band structure) using atomate. I follow the instruction (https://atomate.org/running_workflows.html#prerequisites). But after running some time, I found the “FIZZLED” state instead of running. To Add workflow to LaunchPad and running the workflow, I used below step:
lpad reset
python mgo_bandstructure.py
rlaunch singleshot
Below are mongodb functioning of fireworks:
- _id
5d4348845d924746e1f79dd0
spec
Object
- fw_id
1
- created_on
“2019-08-01T20:16:03.198678”
- updated_on
“2019-08-01T20:16:03.198679”
- name
“MgO-nscf line”
launches
Array
archived_launches
Array
- state
“WAITING”
- _id
5d4348845d924746e1f79dd1
spec
Object
- fw_id
2
- created_on
“2019-08-01T20:16:03.198584”
- updated_on
“2019-08-01T20:16:03.198585”
- name
“MgO-nscf uniform”
launches
Array
archived_launches
Array
- state
“WAITING”
- _id
5d4348845d924746e1f79dd2
spec
Object
- fw_id
3
- created_on
“2019-08-01T20:16:03.198475”
- updated_on
“2019-08-01T20:16:03.198476”
- name
“MgO-static”
launches
Array
archived_launches
Array
- state
“WAITING”
_id : 5d4348845d924746e1f79dd3
spec : Object
fw_id : 4
created_on : "2019-08-01T20:16:03.198222"
updated_on : "2019-08-01T20:17:49.993173"
name : "MgO-structure optimization"
launches : Array
archived_launches : Array
0 : 1
6. state : "FIZZLED"
And at last I got an error below when I used “rlaunch singleshot”.
2019-08-01 22:16:21,937 INFO Hostname/IP lookup (this will take a few seconds)
2019-08-01 22:16:21,938 INFO Launching Rocket
2019-08-01 22:16:26,720 INFO RUNNING fw_id: 4 in directory: /mnt/lscratch/users/skumar/atomate_opt/MgO
2019-08-01 22:16:27,945 INFO Task started: FileWriteTask.
2019-08-01 22:16:27,946 INFO Task completed: FileWriteTask
2019-08-01 22:16:28,191 INFO Task started: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}.
2019-08-01 22:16:28,212 INFO Task completed: {{atomate.vasp.firetasks.write_inputs.WriteVaspFromIOSet}}
2019-08-01 22:16:28,455 INFO Task started: {{atomate.vasp.firetasks.run_calc.RunVaspCustodian}}.
Validation failed: <custodian.vasp.validators.VasprunXMLValidator object at 0x7fd530602400>
c.run()
custodian.custodian.ValidationError: Validation failed: <custodian.vasp.validators.VasprunXMLValidator object at 0x7fd530602400>
2019-08-01 22:17:50,731 INFO Rocket finished
Please suggest me what should I do to remove this error? I would be thankful.
Many thanks and regards
Sandeep
