Hi, everyone:
I am trying to build a shared LAMMPS lib in Cygwin x86_64 environment (setup version 2.859). The mpicxx info is listed below:
$ mpicxx -v
Using built-in specs.
COLLECT_GCC=/usr/bin/g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-cygwin/4.9.2/lto-wrapper.exe
Target: x86_64-pc-cygwin
Configured with: /cygdrive/i/szsz/tmpp/gcc/gcc-4.9.2-1.x86_64/src/gcc-4.9.2/configure --srcdir=/cygdrive/i/szsz/tmpp/gcc/gcc-4.9.2-1.x86_64/src/gcc-4.9.2 --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/libexec --datadir=/usr/share --localstatedir=/var --sysconfdir=/etc --libdir=/usr/lib --datarootdir=/usr/share --docdir=/usr/share/doc/gcc --htmldir=/usr/share/doc/gcc/html -C --build=x86_64-pc-cygwin --host=x86_64-pc-cygwin --target=x86_64-pc-cygwin --without-libiconv-prefix --without-libintl-prefix --libexecdir=/usr/lib --enable-shared --enable-shared-libgcc --enable-static --enable-version-specific-runtime-libs --enable-bootstrap --enable-__cxa_atexit --with-dwarf2 --with-tune=generic --enable-languages=ada,c,c++,fortran,lto,objc,obj-c++ --enable-graphite --enable-threads=posix --enable-libatomic --enable-libgomp --disable-libitm --enable-libquadmath --enable-libquadmath-support --enable-libssp --enable-libada --enable-libgcj-sublibs --disable-java-awt --disable-symvers --with-ecj-jar=/usr/share/java/ecj.jar --with-gnu-ld --with-gnu-as --with-cloog-include=/usr/include/cloog-isl --without-libiconv-prefix --without-libintl-prefix --with-system-zlib --enable-linker-build-id
Thread model: posix
gcc version 4.9.2 (GCC)
The error I got is listed below. It looks like the g++ does not like the declaration “void init(int _N, double _deriv0, double _derivN){” in pair_meam_spline.h
mpicxx -O2 -fopenmp -fPIC -DLAMMPS_GZIP -DLAMMPS_JPEG -DLAMMPS_PNG -DLAMMPS_XDR -DLAMMPS_SMALLSMALL -DLMP_USER_OMP -I…/…/lib/atc -I…/…/src -I…/…/lib/poems -DLMP_MPIIO -DFFT_FFTW3 -I/cygdrive/c/cygwin/usr/local/include -I/usr/local/include/voro++ -c …/force.cpp
…/force.cpp:1:0: warning: -fPIC ignored for target (all code is position independent)
In file included from …/force.cpp:16:0:
…/pair_meam_spline.h:77:31: error: expected ‘,’ or ‘…’ before numeric constant
void init(int _N, double _deriv0, double _derivN) {
In file included from …/style_pair.h:180:0,
from …/force.cpp:22:
…/pair_meam_spline.h: In member function ‘void LAMMPS_NS::PairMEAMSpline::SplineFunction::init(int)’:
…/pair_meam_spline.h:79:34: error: ‘_deriv0’ was not declared in this scope
deriv0 = _deriv0;
…/pair_meam_spline.h:80:34: error: ‘_derivN’ was not declared in this scope
derivN = _derivN;
…/pair_meam_sw_spline.h: At global scope:
…/pair_meam_sw_spline.h:77:31: error: expected ‘,’ or ‘…’ before numeric constant
In file included from …/style_pair.h:182:0,
…/pair_meam_sw_spline.h: In member function ‘void LAMMPS_NS::PairMEAMSWSpline::SplineFunction::init(int)’:
…/pair_meam_sw_spline.h:79:34: error: ‘_deriv0’ was not declared in this scope
deriv0 = _deriv0;
…/pair_meam_sw_spline.h:80:34: error: ‘_derivN’ was not declared in this scope
derivN = _derivN;
Makefile:103: recipe for target ‘force.o’ failed
make[1]: *** [force.o] Error 1
make[1]: Leaving directory ‘/home/jing/lammps/src/Obj_shlib_jing’
Makefile.shlib:42: recipe for target ‘jing’ failed
make: *** [jing] Error 2
Do I miss something? Searched the google and found one similar case back to Oct. 2012 in the thread “Cygwin: error compiling USERS-MISC???” without resolution posted. Any suggestion is greatly appreciated.
jing
Hi, everyone:
$ mpicxx -v
Configured with:
Thread model: posix
declaration "void init(int _N, double _deriv0, double _derivN){" in
pair_meam_spline.h
-DLAMMPS_XDR -DLAMMPS_SMALLSMALL -DLMP_USER_OMP -I../../lib/atc -I../../src
-I../../lib/poems -DLMP_MPIIO -DFFT_FFTW3
../force.cpp
../force.cpp:1:0: warning: -fPIC ignored for target (all code is position
independent)
In file included from ../force.cpp:16:0:
../pair_meam_spline.h:77:31: error: expected ‘,’ or ‘...’ before numeric
constant
In file included from ../style_pair.h:180:0,
from ../force.cpp:22:
../pair_meam_spline.h: In member function ‘void
../pair_meam_spline.h:79:34: error: ‘_deriv0’ was not declared in this scope
deriv0 = _deriv0;
../pair_meam_spline.h:80:34: error: ‘_derivN’ was not declared in this scope
derivN = _derivN;
../pair_meam_sw_spline.h: At global scope:
../pair_meam_sw_spline.h:77:31: error: expected ‘,’ or ‘...’ before numeric
constant
In file included from ../style_pair.h:182:0,
../pair_meam_sw_spline.h: In member function ‘void
../pair_meam_sw_spline.h:79:34: error: ‘_deriv0’ was not declared in this
scope
deriv0 = _deriv0;
../pair_meam_sw_spline.h:80:34: error: ‘_derivN’ was not declared in this
scope
derivN = _derivN;
Makefile:103: recipe for target 'force.o' failed
make[1]: Leaving directory '/home/jing/lammps/src/Obj_shlib_jing'
Makefile.shlib:42: recipe for target 'jing' failed
Oct. 2012 in the thread "Cygwin: error compiling USERS-MISC???" without
this looks as if something is going wrong during preprocessing.
perhaps your cygwin installation defines an incompatible preprocessing
macro.
compilation for windows is only tested regularly using a mingw cross
compiler on linux, and that currently doesn't cause any problems with
MEAM. or USER-MISCl
I checked this and got a clean build from tar-ball including user-misc
and more. For cygwin64, I did the following:
- selected gcc/g++ 4.8 (not sure this is necessary here but my builds
use 4.8)
- added a extra define in the default *serial* makefile for SMALLBIG
(cygwin doesn't define INT64_MAX properly)
[Makefile.mpi]
LMP_INC = -DLAMMPS_GZIP ... -DINT64_MAX=9223372036854775807LL ...
- changed lines 77/78 in "src\pair_meam_sw_spline.h" and
"src\pair_meam_spline.h" to:
77: void init(int _N_, double _deriv0, double _derivN) {
78: N = _N_;
(changed formal argument _N to _N_)
- now I get a clean *serial* (STUBS) build w/cygwin64 (1.733) using
the modules: user-misc, reax, user-reaxc, rigid, poems, mc.
- Then, I added Axel's user-omp and modified the default *mpi*
makefile with the INT64_MAX definition, rebuild.
- Now I have two lammps executeables in cygwin64:
$ ls -la bin/
-rwxr-xr-x 1 user none 54412620 Feb 2 17:44 lmp_mpi.exe
-rwxr-xr-x 1 user none 54286229 Feb 2 17:49 lmp_serial.exe
All builds are smooth without any warning.
Regards
M.
