Dear user,
I have an query about data communication in lammps. In lammps code data communication did in single precession or double precession?
Thanks in advance for your time and consideration.
Notan
Dear user,
Notan
I don’t know if this answers your question, but atom positions, velocities, and forces in LAMMPS are represented using 64bit doubles. (Check out “atom.h”. If you grep " float " *.h in the LAMMPS’ “src/” directory, you’ll see a few places where single precision floats are used, but that code seems to be specific for the calculation of long-range electrostatic interactions.)
Cheers
Andrew
Thanks for your reply. I want to know whether the communication via MPI is done in single precision or double precession in Molecular dynamics code.
Notan
what do you need to know this for?
communication of data is done as 32-bit integer, 64-bit integer and double
precision floating point using (64-bit) doubles as storage elements for the
communication buffers. while encoding of 32-bit integers into doubles can
be done with a typecast, doing the same for 64-bit integer requires a bit
more trickery (see the ubuf struct).
axel
