Hi all,
I would like to kindly ask about retrieving data from Citrine. I am now following the tutorial “experiment_vs_computed_bandgap.ipynb”. I tried to use CitrineDataRetrieval but it returns an error. The retrieval code is as follows:
from matminer.data_retrieval.retrieve_Citrine import CitrineDataRetrieval
api_key = ‘xxxxxxxx’
c = CitrineDataRetrieval(api_key = api_key)
df = c.get_dataframe(prop=‘band gap’, data_type=‘EXPERIMENTAL’,
max_results=100, show_columns=[‘chemicalFormula’, ‘Band gap’])
The error code is:
<details class='elided'>
<summary title='Show trimmed content'>···</summary>
TypeError Traceback (most recent call last)
<ipython-input-8-afa81122e204> in <module>()
5
6 df = c.get_dataframe(prop='band gap', data_type='EXPERIMENTAL',
----> 7 max_results=100, show_columns=['chemicalFormula', 'Band gap'])
8 df.rename(columns={'Band gap': 'Experimental band gap'}, inplace=True) # Rename column
9 df.head()
C:\ProgramData\Anaconda3\lib\site-packages\matminer\data_retrieval\retrieve_Citrine.py in get_dataframe(self, formula, prop, data_type, reference, min_measurement, max_measurement, from_record, data_set_id, max_results, show_columns)
83 reference=reference, min_measurement=min_measurement,
84 max_measurement=max_measurement, from_record=from_record,
---> 85 data_set_id=data_set_id, max_results=max_results)
86
87 non_prop_df = pd.DataFrame() # df w/o measurement column
C:\ProgramData\Anaconda3\lib\site-packages\matminer\data_retrieval\retrieve_Citrine.py in get_api_data(self, formula, prop, data_type, reference, min_measurement, max_measurement, from_record, data_set_id, max_results)
226
227 # Check if any results found
--> 228 if "hits" not in self.client.search(pif_query).as_dictionary():
229 raise KeyError("No results found!")
230
TypeError: 'SearchClient' object is not callable
The package versions are as follows:
python: 3.6.5
matminer: 0.3.1
citrination-client: 4.1.0
pymatgen: 2018.5.14
Since it is a script that exists in a tutorial, I expect that others should be able to run it. Does anyone have the same problem as mine?
Thank you for your answer.
Peerapon
