I’m having trouble defining force-field rules for specific compounds. For example, I have types “o” and an “h” in my force field. I would like to ensure that they are bonded to each other, so I think I should write something like:
ITEM RULES
# id type element index charge rule
0 h H 1 0 H(O(H))
1 o O 2 0 [O](H)(H)
ITEM END
in the .top file. However, when I do this, I get an error:
Warning: missing rules for field './water.prm'.
Warning: missing rule for {group, site} = {wat, 1}.
Warning: missing rule for {group, site} = {wat, 2}.
Error: core/fields.c:432 FieldsApply:
Missing rules.
Program aborted.
It appears that EMC is unable to build a water molecule which satisfies my rules. I’m including my .top, .prm and .esh file for this, so it may be reproduced (both adapted from the field/user example included with EMC). water.esh (696 Bytes) water.prm (983 Bytes) water.top (361 Bytes)
FFDepth - Sets the maximum recursive with which to trace the chemical surrounding
of a site during typing; this depth should equal the maximum depth of the
provided rules
FFDepth indeed controls how deep EMC will follow the chemical tree to match a type. I looked over the included files and would like to point a few EMC idiosyncrasies:
EMC is a little finicky when tabs and white-spaces are concerned: one is advised not to mix them, esp. when force field formats are concerned.
One can include the force field definitions directly into EMC Setup scripts, of which I pasted an example below. This approach has the added benefit, that white-space formatting of the force field files is taken care of by the EMC Script field module.
I took the liberty of adding the SPC/E water parameters to the example below.
You can use the ‘field_debug reduced’ setting to see how EMC interprets rules
#!/usr/bin/env emc_setup.pl
# file: water.esh
# author: Pieter J. in 't Veld
# date: September 27, 2018
# purpose: Example for user-defined force fields using standard force
# field
ITEM OPTIONS
replace true
field_name water
field_location .
#field_debug reduced
density 0.998
temperature 298.15
pressure 1
ntotal 10000
emc_execute true
ITEM END # OPTIONS
# Groups
ITEM SHORTHAND
wat O(H)(H),1.0
ITEM END # SHORTHAND
# Field
ITEM FIELD
ITEM DEFINE
ffmode standard
fftype united
ffdepth 4
cutoff 10
nbonded 3
angle error
torsion error
ITEM END # DEFINE
ITEM MASS
# type mass element ncons charge comment
hw 1.0079 H 1 0 SPCE water H
ow 15.9994 O 2 0 SPCE water O
ITEM END # MASS
ITEM RULES
# type charge rule(s)
hw 0.4238 H(O(H))
ow -0.8476 O(H)(H)
ITEM END # RULES
ITEM NONBOND
# type1 type2 sigma epsilon
hw hw 1.0 0
ow ow 3.16556 0.155394
ITEM END # NONBOND
ITEM BOND
# type1 type2 k l0
hw ow 600 1
ITEM END # BOND
ITEM ANGLE
# type1 type2 type3 k theta0
hw ow hw 75 109.47
ITEM END # ANGLE
ITEM END # FIELD
