I’m trying to plot a Cu stress-strain graph with a script I saw on the internet that uses the following
variable upper_vel equal 0.01 #
fix zeroing_force_on_lower lower setforce 0.0 0.0 0.0
fix zeroing_force_on_upper upper setforce 0.0 0.0 0.0
velocity lower set 0.0 0.0 0.0 units box
velocity upper set 0.0 v_upper_vel 0.0 units box
The problem is that deformation in the y-axis occurs only every 5000 steps.
Step Ly Volume v_strain v_ytensor Temp TotEng Press
0 72.269405 113283.91 -0.00062304519 49.140522 0.009062623 -35189.468 -1473.1663
1000 72.269405 113283.91 -0.00062304519 3202.0166 0.0045077294 -35189.075 -3627.102
2000 72.269405 113283.91 -0.00062304519 6261.7685 0.00024858932 -35187.937 -5616.1535
3000 72.269405 113283.91 -0.00062304519 9062.1089 0.0051519743 -35186.102 -7372.4878
4000 72.269405 113283.91 -0.00062304519 12050.205 0.00025137671 -35183.556 -9286.4894
5000 73.267782 114555.76 0.013183006 14711.52 0.0078857771 -35180.284 -10871.358
6000 73.267782 114555.76 0.013183006 17713.529 0.0079513926 -35176.336 -12772.354
7000 73.267782 114555.76 0.013183006 20568.951 0.012033005 -35171.707 -14496.099
Why might this happen? I know that the fix deform command exists but with this method I see that the author obtained good results.
Cu_u3.eam (35.7 KB)
in_cu.lammps (2.2 KB)
log.lammps (7.7 KB)
