I’m trying to figure out if this is a bug, expected behavior or user error on my part… Unfortunately I don’t quite have a minimal example to share.
I’m currently changing my_fworker.yaml frequently as I try out different settings (e.g. changing NPAR/KPAR, vasp_cmd variables), and then after modification I submit a job using qlaunch. However, I often find the old variables are then picked up.
I observed this when changing KPAR: 8 to NPAR: 4. If I submitted the rlaunch command, explicitly providing the path to my config file, it would correctly pick up the new NPAR: 4 setting. However, using qlaunch, which would generate a FW_submit.script containing the exact same rlaunch command, it would incorrectly pick up the old KPAR: 8 setting. I also observed similar behavior when changing the vasp_cmd variable.
I saw the Fireworks website mentions a qlaunch daemon, so I wasn’t sure if my old settings were persisting somewhere I was unaware of? If so, is there a way to make qlaunch detect the new settings? Or is this user error on my part, and I’m not understanding how Fireworks works correctly?
Many thanks for your help!
Matthew
