To lammps users,
I am testing the density of methanol using a given example of LAMMPS software (~/LAMMPS/Examples/dreading/)
It is known that the density of methanol is ~0.792 g/cm3.
The initial density of methanol example was 0.457 g/cm3 but the density is lower, showing the enlarged unitcell.
How can I get reasonable vlaue (~0.792 g/cm3)?
results##
Step Temp TotEng PotEng KinEng Lx Ly Lz Press Density
0 298.15 12308.081 3094.6323 9213.4485 59.99067 57.38448 58.40913 1781.0418 0.4572555
1000 290.58157 19927.153 10947.585 8979.5683 70.096033 67.050833 68.248084 -92.74926 0.28663535
2000 305.64025 21030.387 11585.475 9444.9127 81.307743 77.77547 79.164219 60.844666 0.1836599
3000 302.94026 21826.71 12465.233 9361.4774 93.059138 89.016346 90.605811 97.386573 0.12249913
input script
units real
atom_style full
dielectric 1
special_bonds lj/coul 0.0 0.0 1.0
pair_style hybrid/overlay hbond/dreiding/lj 2 6 6.5 90 lj/cut/coul/long 8.50000 11.5
bond_style harmonic
angle_style harmonic
dihedral_style harmonic
improper_style none
kspace_style pppm 0.001
read_data data.dreiding
replicate 3 3 3
pair_coeff 1 1 lj/cut/coul/long 0.015200000256300 2.846421344984478
pair_coeff 1 2 lj/cut/coul/long 0.001232882795416 2.846421344984478
pair_coeff 1 3 lj/cut/coul/long 0.038019995160237 3.159705878878677
pair_coeff 1 4 lj/cut/coul/long 0.038139744011598 2.939787518071103
pair_coeff 2 2 lj/cut/coul/long 9.99999974737875e-05 2.846421344984478
pair_coeff 2 3 lj/cut/coul/long 0.003083828758188 3.159705878878677
pair_coeff 2 4 lj/cut/coul/long 0.003093541672406 2.939787518071103
pair_coeff 3 3 lj/cut/coul/long 0.095100000500679 3.472990412772877
pair_coeff 3 4 lj/cut/coul/long 0.095399530150179 3.253072051965302
pair_coeff 4 4 lj/cut/coul/long 0.095700003206730 3.033153691157727
pair_coeff 4 4 hbond/dreiding/lj 2 i 0.4000E+01 2.750000000000000 4
pair_modify mix arithmetic
neighbor 2.0 multi
neigh_modify every 2 delay 4 check yes
variable input index in.ch3oh.box.dreiding
variable sname index ch3oh.box.dreiding
compute hb all pair hbond/dreiding/lj
variable C_hbond equal c_hb[1] #number hbonds
variable E_hbond equal c_hb[2] #hbond energy
#thermo_style custom etotal ke temp pe ebond eangle edihed eimp evdwl ecoul elong v_E_hbond v_C_hbond press vol
#thermo_modify line multi format float %14.6f
Output
thermo 1000
thermo_style custom step temp etotal pe ke lx ly lz press density
dump myOvito all custom 1000 dump.ovito.* id type xs ys zs
################### NPT
timestep 1
velocity all create 298.15 4928459 rot yes mom yes dist gaussian
#fix ensemble_press all press/berendsen iso 1.0 1.0 1000.0
fix fxnpt all npt temp 300.0 300.0 100.0 iso 1.0 1.0 100.0
run 100000
unfix fxnpt
#unfix ensemble_press
reset_timestep 0
