Deposit command, not take fix nvt of structure.
hello
i try to simulate a deposition of GaAs atoms in a GaAs surface, i use a GaAs sustrate, and create a enviroment where i put atoms of Ga and As.
the problem is if i created the GaAs atoms in gaas before simulation, this atoms move and are deposited in good matter, but when i use deposit command the atoms added with deposit not move (i think this atoms not move becouse i dont use vx/vz/vy parameters) but if i use this parameters all atoms could take the same direction, and i dont see the fix nvt take effect in this new atoms deposited with the command deposit, i see a new option (rate) but i dont know if this option could move the atoms in randoms directions, and take the fix nvt defined in this area.
i add the code more bellow
King Regards
Code:
Initialize
clear
boundary p p f
atom_style atomic
Create atoms
read_data data.GAAS
SW Potential
pair_style sw
pair_coeff * * parametros.sw Ga As
Define Settings
region r_bottom block INF INF INF INF INF 3.0 units box
group g_bottom region r_bottom
region r_middle block INF INF INF INF 3.0 49.0 units box
group g_middle region r_middle
region r_top block INF INF INF INF 65.0 INF units box
group g_top region r_top
region r_deposition block INF INF INF INF 50.9 64.9 units box
group g_deposition region r_deposition
region r_gas block INF INF INF INF 65.0 INF units box
group g_gas region r_gas
region depo block 5.0 97.0 5.0 97.0 70.0 215.0
#parametros
velocity g_gas create 1000 492459 rot yes dist gaussian
fix nve_deposition g_deposition nve
fix fix_bottom g_bottom setforce 0.0 0.0 0.0
fix nvt_middle g_middle nvt temp 600 800 0.1
fix nvt_gas g_gas nvt temp 1000 1200 0.1
fix muro all wall/reflect zhi EDGE
thermo 5000
thermo_modify lost ignore
dump salidadump all atom 20000 dump.salidagaas
timestep 0.001
run 600000
minimize 1.0e-4 1.0e-6 1000 10000
fix 6 all deposit 300 1 10 67546 region depo near 4.2 units box
fix 7 all deposit 300 2 10 69546 region depo near 4.2 units box
run 600000
dump dumpfinal all atom 100000 dump.final
The fix deposit command allows you to specify a range of velocities
for new atoms, in x,y, and/or z. The actual velocity of one atom
will be chosen randomly from those ranges. You probably don’t want
the thermostat to apply to the new atoms, at least not immediately.
I suggest you use fix langevin on the substrate atoms.
hello
no. your deposited atoms do not move because they are not time integrated.
in your input to apply time integration to groups:
g_deposition, g_middle and g_gas
however, you do not add your deposited atoms to any of those groups.
only to group all.
hello
i add the deposit to group and add one fix nvt but atoms continue without move.
i add lines with *** , but nothing happend in simulacion.
thank alot.
CODE:
Initialize
clear
boundary p p f
atom_style atomic
Create atoms
read_data data.GAAS
SW Potential
pair_style sw
Define Settings
group g_gas_d region depo ***
#parametros
#fix nvt_deposition g_deposition nvt temp 600 800 0.1
#fix nvt_middle g_middle nve
fix nvt_gas_d g_gas_d nvt temp 1000 1200 0.1 ***
thermo 5000
#thermo_style custom step temp pe etotal
Diffusion run
#si el paso es mas grade da NaN (0.05 fallaba).
timestep 0.001
restart 100000 deposicion.restart
run 600000
#los valores de gaas depositados con estos parametros no se mueven.
run 600000
hello
only to group all.
