Dear users,
I have reviewed the examples on calculation of thermal conductivity in lammps package and also reviewed few available numerical examples in lammps forum. Still I am confused and do not know how to extract the thermal conductivity from outputs of fix thermal/conductivity.
For example, do I have to multiply number of atoms by exchanged kinetic energy? If we have a bilayer graphene system then what is the thickness? is it the whole z direction or only 2*thickness of one graphene layer?
How the elapsed time is calculated? A numerical derivation would be extremely helpful.
Thanks.
Nima Pirouzmand
The file examples/KAPPA/README explains exactly how
a value was extracted from each of the 3 inputs scripts (and
their output) in that dir.
Prof. Plimpton,
You are right.I did not attention to that file before.
Thank you.
Nima Pirouzmand
The thickness of a 2D material in classical molecular dynamics with point-like particles is ill-defined. Different authors use different (arbitrary for that matter) references, which is pretty messy. For a single layer of graphene, you can for example use a thickness based on the range of your potential, the amplitude of the vibrations, or something like twice the carbon van der Waals radius (2*1.7 A) - for a bilayer, look at what people are using in the literature. You have to be careful with what you are comparing your result if you choose a reference.
Arthur
Dear Arthur,
Thank you very much for your informative response.
Nima Pirouzmand
