it seems that the formula for the improper_style umbrella in the manual
E = 0.5 * K ((1+cos(w0)/sin(w0))^2 * (cos(w) - cos(w0)), when w0 != 0
is different from the one in the original paper:
E = 0.5 * K (1/sin(w0))^2 * (cos(w) - cos(w0))^2.
I took a quick peek into the code, and it seems to be using the formula from the paper.
What is the reason for this difference?
Thank you for your time.
Tod implemented this for LAMMPS, who is familiar with
the Dreiding FF. I’ve CCd - hopefully he can answer.
Trying again with a different email for Tod.
Hi Steve/Donatas:
As Donatas pointed out, the formula in the manual is incorrect and should be updated to be consistent with the code and the paper:
–Tod
Hi Steve/Donatas:
i've included that in my branch and will forward it to steve at the next
occasion when he has time again to incorporate patches.
what about the second expression for w0 = 0?
shouldn't that be 0.5 * K *(1 - cos(w))^2 ?
that looks more similar to the w0 != 0 expression for small w0
Hi Axel:
No, if the equilibrium angle is 0 (i.e. the atoms bonded to the central atom I are coplanar), the potential is replaced with
E = K(1-cos(w))
as written (note the 1/2 factor is removed)
–Tod
Thanks for the quick response Tod - as Axel said, we’ll make
the change in the doc page …
