Hello everyone,
I use the TIP4P-2005 water model to simulate the two-phase process of water, but when I change the parallel core number from 100 to 20, the outcome of the simulation changes a lot.
I can’t understand why, should I change the simulation parameters such as the timestep while I set it as 2fs now or any other parameters to solve this problem?
Hello everyone,
what do you mean by "outcome changes a lot"? is it just different
positions of individual atoms, or significant differences in (averaged)
properties?
also, *always* mention the LAMMPS version you are using and best provide
your input file, too, so that people can check, whether there are obvious
mistakes somewhere.
I can't understand why, should I change the simulation parameters
solve this problem?
diverging trajectories with different number of cores, even different
implementations of the same potential, are quite normal, as LAMMPS employs
floating point math and floating point math does not associate (e.g. the
exact outcome can be slightly different for all properties that are summed
up in different order) which will result in an exponentially growing
difference between such runs.
so at this moment, it is not even clear, whether you are reporting a real
issue, or just physics and numerical science at work.
fix 0 all indent 10.0 sphere $L $L $L r units box
fix 1 all shake 0.0001 100 0 b 1 a 1
fix barostat all npt temp 298.0 298.0 (100.0*dt) iso {Pstart} {Pstop} (1000.0*dt) drag 1.0
fix print_press all print 1 "{PRESS}" file press.dat screen no title “”
fix print_vol all print 1 “${VOL}” file vol.dat screen no title “”
run
thermo_style custom step temp press vol
thermo ${THERMO}
run 250000
The simulation is designed to mimic the cavitation in water at a low pressure, and the “outcome changes a lot” means the vol-time curves in the simulations are different. The vol variable in the 100 core simulation is increasing much quicker than in the 20 core simulation, which makes me confused.
So, what I want to ask for advice is that is there any other factors except the “floating point error” that cause this situation? Because I think the the “outcome change” in the two simulation is really beyond my expectation.
Thank you very much!
