Dear All users,
I want to calculate the water diffusion coefficient in the
directions perpendicular and parallel to the surface. Is it possible in lammps e.g with using fix ave/spatial command?
Dear All users,
Dear Yanqing,
I knew and I have calculated successfully the diff coeff for a bulk of water. But I wanted to know when there is a bulk of water on a surface it is possible to calculate diff coeff
versus distance from the surface e.g in direction z or not.
Compute msd will give you the x,y,z components of MSD.
Dear Steve,
Thank you for your reply, but I meant I want to record diff coeff for every 1 angstrom intervals from the surface.
Dear Steve,
That just doesn’t make sense.
How would you want to treat an atom that diffuses from one layer to the next? Or crosses multiple?
Dear Axel,
There is some molecules near the surface which have been covered by those molecules and other molecules are located far from this layer.
But I think, I have no answer for your question,
Dear Axel,
So what?
What has this to do with your question?
I have studied an article including this analysis and I wanted to do this analysis for my system. They calculated diff coeff as a function of distance from the surface.
you are a hopeless case.
this *still* doesn't answer the question how you will be handling the
ambiguity i mentioned (or people in the paper did). unless you come up
with an answer for this very fundamental issue, nobody with integrity
will be able to provide a suggestion.
so put your thinking cap on and put that brain of yours to work.
Anyway, Axel
well, and you too.
I meant you are right, did you mean I was right?
is that a trick question?
take it easy Axel, you are always right.
just trying to show you how it is when people respond by not answering
your question.
So, I’m starving and have to eat.
FYI : http://multiscalelab.org/utilities/DiffusionCoefficientTool
Play with this and I think you will find the answer
Best Wishes!
Dear Yanqing,
Thank you for your reply and try to help me, as I said before, I want to calculate diff coeff as a function of distance.
Besides, this is a good tools for a small molecule such as water. I used to use it in VMD, maybe lammps tools is more useful than it.
