I used the script "charmm2lammps.pl" to generate an input lammps
"data" file for naphtalene
(starting from a "psf" file generated with the "charmm" program, and
using the topology and parameter files
"top_all36_cgenff.top" and "par_all36_cgenff.prm") .
8 11
7 10
6--5 9 12--13
4--3 18 14--15
1 16
2 17
Fig1. Naphalene structure with atom numbering
In the Dihedral section of the generated "data" file, all dihedrals
involving four aromatic carbons are of the same type (consistently
with how naphtalene is modelled within CGENFF). For example (see Fig.1
above for atom numbering i, j, k, l):
#dih_id dih_type i j k l
2 1 1 3 5 7 #CG2R61 CG2R61
CG2R61 CG2R61
3 1 1 18 9 7 #CG2R61 CG2R61
CG2R61 CG2R61
4 1 1 18 9 10 #CG2R61 CG2R61
CG2R61 CG2R61
In the Dihedral Coeff secion, the parameters for this dihedral type are:
#dih_type K n d weight
1 3.1 2 180 0.5 #CG2R61
CG2R61 CG2R61 CG2R61
I think that using weight=0.5 for 1-4 nonbonded interactions is
correct for dihedrals like dih_id=2 and 3, but not for dih_id=4 (for
this, I would use weight=1.0, since there isn't another dihedral
having atoms 1 and 10 as terminal atoms).
Am I correct, or am I missing something ?
If I am correct, the only solution that came to my mind is to manually
modify the "data", by (i) defining a new dihedral type with the same
value of K,n,d of dih_type=1 but with a weight=1.0; (ii) assigning
dihedrals like dih_id=4 to this new type:
1 3.1 2 180 0.5
2 3.1 2 180 1.0
2 1 1 3 5 7
3 1 1 18 9 7
4 2 1 18 9 10
Is this the only possible solution, or does lammps provide some
special keyword for treating cases like this?
(the molecule I have to model is much more complicated than
naphtalene, and manually modifying the file would be a bit tedious).
Thanks a lot for your help
Cristina
