I use the Langzhiwan kinetic equation to simulate the aggregation process of nanoparticles.
Here is my script:
units nano
lattice sc 6.0
atom_style sphere
neighbor 1.0 bin
region box block -12 12 -12 12 -12 12
create_box 1 box
create_atoms 1 box
set type 1 diameter 3
set type 1 mass 1
pair_style lj/cut 2.5
pair_coeff * * 1.0 1.0 2.5
velocity all create ${T} 12345 dist gaussian
fix 1 all nve
fix 2 all press/berendsen iso 1.0 1.0 100
fix 3 all langevin 300 300 1.0 12345
#timestep 0.00001
thermo 100
thermo_style custom step temp pe ke etotal press
dump myDump all custom 100 dump.nanoparticles id type x y z vx vy vz radius
run 1000
The particle diameter in the script is set to 3nm,
If I want to simulate particles with a diameter of 30nm,
So should the sigma, epsilon, and truncation radius in the potential function change?
If I want to dimensionless the system using LJ units, with a selected feature length of 60nm, feature time of 1fs, and feature mass of 1kg, how should I normalize other physical quantities in the script?
