Hello, the output of entry.as-dict() is:
python3.12/site-packages/pymatgen/entries/compatibility.py: 621: UserWarning: Failed to guess oxidation states for Entry vasprun-20250723-2.0-be3500236364da0779484cd7b3d1960e (ScTeRh). Assigning anion correction to only the most electronegative atom.
adjustments: list[EnergyAdjustment
] = self.get_adjustments(entry)
{'@module': 'pymatgen.entries.computed_entries', '@class': 'ComputedStructureEntry', 'energy': -79.39333173, 'composition': {'Sc': 4.0, 'Te': 4.0, 'Rh': 4.0
}, 'entry_id': 'vasprun-20250723-2.0-be3500236364da0779484cd7b3d1960e', 'correction': 0.0, 'energy_adjustments': [], 'parameters': {'potcar_symbols': ['PAW_PBE Sc_sv 07Sep2000', 'PAW_PBE Te 08Apr2002', 'PAW_PBE Rh_pv 25Jan2005'
], 'potcar_spec': [
{'titel': 'PAW_PBE Sc_sv 07Sep2000', 'hash': 'c908d92f64698d610daf891fe81b4c57', 'summary_stats': {'keywords': {'header': ['eatom', 'eaug', 'enmax', 'enmin', 'iunscr', 'lcor', 'lexch', 'lpaw', 'lultra', 'ndata', 'orbitaldescriptions', 'orbitals', 'pomass', 'raug', 'rcloc', 'rcore', 'rdep', 'rdept', 'rmax', 'rpacor', 'rrkj', 'rwigs', 'step', 'titel', 'vrhfin', 'zval', 'nentries'
], 'data': ['localpart', 'gradientcorrectionsusedforxc', 'corecharge-density(partial)', 'kineticenergydensity(partial)', 'atomicpseudocharge-density', 'nonlocalpart', 'reciprocalspacepart', 'realspacepart', 'reciprocalspacepart', 'realspacepart', 'nonlocalpart', 'reciprocalspacepart', 'realspacepart', 'reciprocalspacepart', 'realspacepart', 'nonlocalpart', 'reciprocalspacepart', 'realspacepart', 'reciprocalspacepart', 'realspacepart', 'pawradialsets', '(5e20.12)', 'augmentationcharges(nonsperical)', 'uccopanciesinatom', 'grid', 'aepotential', 'corecharge-density', 'kineticenergy-density', 'mkineticenergy-densitypseudized', 'localpseudopotentialcore', 'pspotentialvalenceonly', 'corecharge-density(pseudized)', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'endofdataset'
}, 'stats': {'header': {'MEAN': 47.21291675983607, 'ABSMEAN': 47.21291675983607, 'VAR': 19124.301896512028, 'MIN': 0.0, 'MAX': 1273.2868
}, 'data': {'MEAN': 475.1501349476418, 'ABSMEAN': 511.0884049869529, 'VAR': 25628201.733524792, 'MIN': -324.624570873, 'MAX': 86058.8575637
{'titel': 'PAW_PBE Te 08Apr2002', 'hash': '11ac22d05d08fb6be6beb8cf78b0127c', 'summary_stats': {'keywords': {'header': ['dexc', 'eatom', 'eaug', 'enmax', 'enmin', 'icore', 'iunscr', 'lcor', 'lexch', 'lpaw', 'lultra', 'ndata', 'orbitaldescriptions', 'orbitals', 'pomass', 'raug', 'rcore', 'rdep', 'rdept', 'rmax', 'rpacor', 'rrkj', 'rwigs', 'step', 'titel', 'vrhfin', 'zval', 'nentries'
], 'data': ['localpart', 'gradientcorrectionsusedforxc', 'corecharge-density(partial)', 'kineticenergydensity(partial)', 'atomicpseudocharge-density', 'nonlocalpart', 'reciprocalspacepart', 'realspacepart', 'reciprocalspacepart', 'realspacepart', 'nonlocalpart', 'reciprocalspacepart', 'realspacepart', 'reciprocalspacepart', 'realspacepart', 'nonlocalpart', 'reciprocalspacepart', 'realspacepart', 'pawradialsets', '(5e20.12)', 'augmentationcharges(nonsperical)', 'uccopanciesinatom', 'grid', 'aepotential', 'corecharge-density', 'kineticenergy-density', 'mkineticenergy-densitypseudized', 'localpseudopotentialcore', 'pspotentialvalenceonly', 'corecharge-density(pseudized)', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'pseudowavefunction', 'aewavefunction', 'endofdataset'
}, 'stats': {'header': {'MEAN': 11.730298631707315, 'ABSMEAN': 11.730298631707315, 'VAR': 2151.9821126635975, 'MIN': 0.0, 'MAX': 368.792
}, 'data': {'MEAN': 12099.175277456627, 'ABSMEAN': 12120.200312191555, 'VAR': 12921969032.046568, 'MIN': -547.38786, 'MAX': 1741274.85585
{'titel': 'PAW_PBE Rh_pv 25Jan2005', 'hash': '7754470ff260ceb531591deb18e597cd', 'summary_stats': {'keywords': {'header': ['dexc', 'eatom', 'eaug', 'enmax', 'enmin', 'icore', 'iunscr', 'lcor', 'lexch', 'lpaw', 'lultra', 'ndata', 'orbitaldescriptions', 'orbitals', 'pomass', 'raug', 'rcore', 'rdep', 'rdept', 'rmax', 'rpacor', 'rrkj', 'rwigs', 'step', 'titel', 'vrhfin', 'zval', 'nentries'
}, 'stats': {'header': {'MEAN': 86.35735590569105, 'ABSMEAN': 86.35735590569105, 'VAR': 56303.57052008248, 'MIN': 0.0, 'MAX': 2226.4782
}, 'data': {'MEAN': 6458.014504975984, 'ABSMEAN': 6505.45362931229, 'VAR': 4284326189.248586, 'MIN': -452.967881648, 'MAX': 1059322.85023
], 'run_type': 'GGA', 'is_hubbard': False, 'hubbards': {}
}, 'data': {'oxidation_states': {}
}, 'structure': {'@module': 'pymatgen.core.structure', '@class': 'Structure', 'charge': 0.0, 'lattice': {'matrix': [
6.31287624,
-0.0,
-0.0
-0.0,
6.31287627,
-0.0
-0.0,
-0.0,
6.31287629
], 'pbc': (True, True, True), 'a': 6.31287624, 'b': 6.31287627, 'c': 6.31287629, 'alpha': 90.0, 'beta': 90.0, 'gamma': 90.0, 'volume': 251.5833127936602
}, 'properties': {}, 'sites': [
{'species': [
{'element': 'Sc', 'occu': 1
], 'abc': [
-1.2e-07,
-2e-08,
3e-08
], 'properties': {}, 'label': 'Sc', 'xyz': [
-7.575451487999999e-07,
-1.262575254e-07,
1.8938628869999998e-07
{'species': [
], 'abc': [
-1.3e-07,
0.50000002,
0.49999997
-8.206739112e-07,
3.1564382612575255,
3.1564379556137117
{'species': [
], 'abc': [
0.50000013,
-2e-08,
0.49999997
3.156438940673911,
-1.262575254e-07,
3.1564379556137117
{'species': [
], 'abc': [
0.50000013,
0.50000002,
3e-08
3.156438940673911,
3.1564382612575255,
{'species': [
{'element': 'Te', 'occu': 1
], 'abc': [
0.5,
0.5,
0.5
], 'properties': {}, 'label': 'Te', 'xyz': [
3.15643812,
3.156438135,
3.156438145
{'species': [
], 'abc': [
0.5,
-0.0,
0.0
3.15643812,
0.0,
0.0
{'species': [
], 'abc': [
0.0,
0.5,
0.0
0.0,
3.156438135,
0.0
{'species': [
], 'abc': [
0.0,
-0.0,
0.5
0.0,
0.0,
3.156438145
{'species': [
{'element': 'Rh', 'occu': 1
], 'abc': [
0.25,
0.25,
0.25
], 'properties': {}, 'label': 'Rh', 'xyz': [
1.57821906,
1.5782190675,
1.5782190725
{'species': [
], 'abc': [
0.75,
0.75,
0.25
4.734657179999999,
4.7346572025,
1.5782190725
{'species': [
], 'abc': [
0.75,
0.25,
0.75
4.734657179999999,
1.5782190675,
4.734657217500001
{'species': [
], 'abc': [
0.25,
0.75,
0.75
1.57821906,
4.7346572025,
4.734657217500001
