Hello, everyone!
It’s maybe not a suitable theme for this user lists, but I am confused. Hope someone can give me some suggestions.
What I need to calculate are the melting point and the volume change on melting of bcc-Fe.
At the very beginning, I estimated the melting point by increasing the temperature in NPT ensemble and monitor the volume change or MSD (method1). A sharp increase of the volume change or MSD corresponds to the melting point. The volume change can be obtained simultaneously.
But the referee said it was not an accurate method to obtain the melting point for over-heating. He said the truth. What I calculated is about 2200K, which was higher than the experimental value, say 1811K.
Though he didn’t mention any accurate methods, I found the two-phase method was a better method (method2). I re-calculated the melting point using solid-liquid interface / NVE method and obtained the result 1870K, which was indeed better.
But I don’t know how to obtain the volume change based on method2 because the volume remained unchanged during the simulation. I don’t want to use the volume change based on method1 for its mis-estimating the melting point.
Regards!
