Hi LAMMPS Users,
I am trying to construct a dislocation by positioning the atomic planes such that a dislocation will be generated after the minimization at the centre of the box. I can create the geometry which looks good in visualization as well. I need to minimize the energy while allowing the box to expand.
I am using box/relax along with minimize. I intend to impart strain in successive quasistatic steps after the minimization. I am also fixing the top and bottom slab of few atoms each and constraining them by fix setforce 0 0 0.
When I run the minimization, the temperature and pressure in thermodynamic output doesnot corrrespond to 0 K and 0 pressure. I was wondering whether it is a consequence of constraining by setforce, or it is something else? I doubt it as a consequence of setforce. If it is, does it make sense to use different compute id of temperature and pressure corresponding to nonfrozen atoms? What does that signify physically? And while straining it, temperature and pressure corresponding to which group of atoms would be more sensible.
Attaching the input file for your perusal
variable TEMP equal 0.0
variable LATSCALE equal 1.0
variable NINIT equal 9
variable XTOP1 equal 1
variable XTOP2 equal 1
variable XTOP3 equal 1
variable YTOP1 equal 1
variable YTOP2 equal -1
variable YTOP3 equal 0
variable ZTOP1 equal 1
variable ZTOP2 equal 1
variable ZTOP3 equal -2
variable unitX equal 1.73205*0.5
variable unitY equal 1.41421
variable unitZ equal 2.44950
variable SIZEX equal 80
variable SIZEY equal 80
variable SIZEZ equal 12
variable HALFX equal {SIZEX}*0.5
variable HALFY equal {SIZEY}*0.5
variable LENGTHX equal ${SIZEX}*1.0001
variable LENGTHY equal {SIZEY}*1.00
variable LENGTHZ equal {SIZEZ}*1.0001
variable UPPERX equal ${SIZEX}*1.000001
variable LOWERX equal ({SIZEX}-1)*1.0001 variable FINALX equal ({SIZEX}-0.5)*1.000001
variable sclUPP equal {FINALX}/{UPPERX}
variable sclLOW equal {FINALX}/{LOWERX}
variable HALFLX equal 0.5*{LENGTHX} variable HALFLY equal 0.5*{LENGTHY}*1.0000001
variable frozenslab equal 10
variable latparam equal 2.85531344*${LATSCALE}
variable cutoffpctg equal 0.7
variable delcutoff equal 0.5sqrt(3){latparam}*{cutoffpctg}
variable NCLUST equal 1
variable DISTY equal 0.0
variable DISTX equal 30.0
variable helrad equal 0.5
variable SIZECLUST equal 3
log LOG.create.CLUSTER.EDGE.dislocation.SHEAR.INIT.{NINIT}.{SIZEX}.{SIZEY}.{SIZEZ}.txt
clear
atom_style atomic
box tilt large
lattice bcc {latparam} spacing {unitX} {unitY} {unitZ} orient x {XTOP1} {XTOP2} {XTOP3} orient y {YTOP1} {YTOP2} {YTOP3} orient z {ZTOP1} {ZTOP2} ${ZTOP3}
region box prism 0 {LENGTHX} 0 {LENGTHY} 0 ${LENGTHZ} 0 0 0 units lattice
create_box 2 box
region uppbox prism 0 {UPPERX} 0 {HALFLY} 0 {LENGTHZ} 0 0 0 units lattice region lowbox prism 0 {LOWERX} {HALFLY} {LENGTHY} 0 ${LENGTHZ} 0 0 0 units lattice
create_atoms 1 region uppbox
create_atoms 1 region lowbox
group upper region uppbox
group lower region lowbox
pair_style eam/fs
pair_coeff * * FeHe-with_radcrit_0.50.eam.fs Fe He
neighbor 2.0 bin
neigh_modify delay 10 check yes
delete_atoms overlap ${delcutoff} all all
compute poteng all pe/atom
thermo 1000
thermo_style custom step pe ke etotal temp pxx pyy pzz press vol lx ly lz
#dump dump2 all xyz 1 XYZ.create.EDGE.dislocation.*.xyz
variable xupp atom x*({sclUPP}-1) variable xlow atom x*({sclLOW}-1)
fix 1 upper move variable v_xupp NULL NULL NULL NULL NULL
fix 2 lower move variable v_xlow NULL NULL NULL NULL NULL
run 1
unfix 1
unfix 2
change_box all x final 0 {FINALX} units lattice delete_atoms overlap {delcutoff} all all
variable LENGTHXX1 equal lx
variable LENGTHYY1 equal ly
variable LENGTHZZ1 equal lz
variable lowery equal ylo
variable uppery equal yhi
variable freezeLO equal {lowery}+{frozenslab}
variable freezeUP equal {uppery}-{frozenslab}
region freeze1 prism EDGE EDGE {lowery} {freezeLO} EDGE EDGE 0 0 0 units box
region freeze2 prism EDGE EDGE {freezeUP} {uppery} EDGE EDGE 0 0 0 units box
group frozenlo region freeze1
group frozenup region freeze2
region freeze union 2 freeze1 freeze2
group frozen region freeze
include adding.clusters.N${NCLUST}.size${SIZECLUST}.init${NINIT}.y[{DISTY}].x[{DISTX}].in
group helium type 2
group nonfrozenhel subtract all frozen
group nonfrozen subtract nonfrozenhel helium
fix freezeatoms frozen setforce 0.0 0.0 0.0
dump dump1 nonfrozenhel cfg 10000 DUMP/CFG.create.CLUSTER.EDGE.INIT${NINIT}.NCLUST${NCLUST}.DISTY${DISTY}.DISTX${DISTX}.*.cfg mass type xs ys zs id
dump_modify dump1 element Fe He
thermo 100
fix 1 all move variable NULL NULL NULL NULL NULL NULL
run 1
unfix 1
fix 1 all box/relax aniso 0.0
min_style cg
minimize 1e-15 1e-15 50000 100000
