rohit_p
#1
Hello all,
I want to displace certain number of atoms for every timestep. Is using ‘every’ keyword in run the only way or is there
some other way?
And is it possible to extract LJ energy of atoms while using a hybrid potential containing LJ and another potential?
Rohit.
Hello all,
'every' keyword in run the only way or is there
some other way?
use fix move ?
depends. what are the potentials and are you
using hybrid or hybrid overlay?
rohit_p
#3
Hello Axel,
I think Fix_move should do the trick. I really should go through the documentation again
I am actually using LJ/CUT and AIREBO potentials through HYBRID.
Is it possible to extract the LJ energy alone?
Rohit.
Hello Axel,
documentation again
yes!
you can use compute group/group between the groups that
are connected through lj/cut.
see above about the documentation.
See the compute pair command which allows you to
extract energies from pair styles, including sub-styles
of pair_style hybrid.
