Displace_atoms with atom-style variable
Dear LAMMPS community, I am facing a small problem regarding the “displace_atoms” command.
Currently, I am working with the 15th May 2015 LAMMPS version.
I am simulating a LJ liquid in the NVE ensemble and I have the necessity to slightly change the box size along the z direction, and to change the z positions of the atoms in the boundary regions according to a formula involving their z coordinates. I would like to use an atom-style variable for saving each atom’s displacement (according to this formula), and use it inside the “displace atom” command.
The relevant part of my input script is:
variable deltaz equal (v_DeltaZ/v_check_freq) variable displ atom (z-({z0}))/(({z1})-({z0}))*({deltaz}) run {nsteps}
change_box all z delta (-v_deltaz) {deltaz} units lattice
displace_atoms ext_region move 0 0 ${displ} units lattice
Where all the variables involved in these formulas have already been defined before in the script, and this part of the code is inside a loop (this displacement happens every ${nsteps} steps).
The part related to the “change_box” command is correctly working, while the last line is causing me some trouble.
Trying to run this simulation, I get this error:
Substitution for illegal variable
referring to the line with the “displace_atoms” instruction.
Therefore, my question is: am I allowed to use an atom-style variable in this situation? According to the online manual it seems so (“Any of the 3 quantities defining the vector components can be specified as an equal-style or atom-style variable”), but I am not able to make it work, at the moment.
Any help appreciated, thanks in advance!
Francesco Mambretti
Laboratorio di Calcolo Parallelo e di Simulazioni di Materia Condensata, Dipartimento di Fisica, Università degli Studi di Milano
"displace_atoms" command.
for saving each atom's displacement (according to this formula), and use it
inside the "displace atom" command.
variable deltaz equal \(v\_DeltaZ/v\_check\_freq\) variable displ atom \(z\-\({z0}))/((\{z1\}\)\-\({z0}))*(\{deltaz\}\) run {nsteps}
change_box all z delta \(\-v\_deltaz\) {deltaz} units lattice
The part related to the "change_box" command is correctly working, while the
referring to the line with the "displace_atoms" instruction.
this situation? According to the online manual it seems so ("Any of the 3
or atom-style variable"), but I am not able to make it work, at the moment.
the problem seems to be, that you are not considering, that there are
two *different* ways of accessing a variable.
you are only using *immediate* expansions (using ${name}) which will
translate variables to text and then feed LAMMPS that expanded line.
you can see those expansions when you run LAMMPS with -echo screen.
this is totally transparent to the individual LAMMPS commands.
for atom style variables, this doesn't make sense, and in any case
when the LAMMPS documentation mentions that a command accepts a
variable, it means that you can provide a variable *reference* in the
form v_name. this reference will not be immediately expanded, but
evaluated whenever the corresponding command references it internally,
i.e. in case of a fix repeatedly during a simulation.
so i suggest you re-read the documentation of the variable command
with this information in mind, and you should be able to figure out
how to do what you want to do.
I’ve re-read the documentation and changed my script according to what I’ve understood, but now I get a different error.
My new input script is like:
variable deltaz equal $(v_DeltaZ/v_check_freq)
variable displ atom (z-(${z0}))/((${z1})-(${z0}))*(${deltaz})
run ${nsteps}
change_box all z delta $(-v_deltaz) ${deltaz} units lattice
displace_atoms ext_region move 0 0 v_displ units lattice
And now the output (with -echo screen option) is:
displace_atoms ext_region move 0.0 0.0 v_displ units lattice
Displacing atoms …
ERROR: Expected floating point parameter in input script or data file (…/displace_atoms.cpp:94)… when it arrives to the last line.
Why? What am I missing again?
Thanks in advance,
Francesco
I've re-read the documentation and changed my script according to what I've
Displacing atoms ...
(../displace_atoms.cpp:94)... when it arrives to the last line.
that you probably checked the online documentation, which always
describes the latest patchlevel of LAMMPS, while you seem to be using
a version of LAMMPS that predates the implementation of variable
support in displace atoms.
you can see the history of (significant) changes here:
LAMMPS Molecular Dynamics Simulator and the links to the history of
previous years.
in your case, check out LAMMPS Molecular Dynamics Simulator around october.
