alberto
September 18, 2018, 1:40pm
#1
I’m trying to run a nvt (298K) simulation of DMSO
correctly my box simulation has got 68 molecules in a volume of 8000 A.
I fixed molecule during the simulation
Atom Groupings
group DMSO id <> 1 680
END Atom Groupings
fix DMSONVE DMSO rigid/nve/small molecule langevin 298.0 298.0 10. 123
timestep 2
run 2000
unfix DMSONVE
reset_timestep 0
compute T all temp
fix TempAve all ave/time {Ne} {Nr} ${Nf} c_T
variable Dens equal v_nMolecules*{DMSOMoleculeMass}/(vol* {A3_in_mL}) # dens g/mL
fix DensAve all ave/time {Ne} {Nr} ${Nf} v_Dens file DMSO.dens
#give an initial random velocity (corresponding to a temperature equal to 298K)
velocity DMSO create 298 1233 rot yes mom yes dist uniform
#apply Langevin thermostat on water molecules
fix DMSOlang DMSO langevin 298.0 298.0 10. 123
run dynamic at 298K
fix 1 DMSO rigid/nvt/small molecule temp 298.0 298.0 1.0
the results is that the system is not stable and the pressure bad!!
Step Volume Temp f_TempAve Press TotEng PotEng KinEng E_vdwl E_coul E_bond E_angle E_dihed E_impro f_DensAve
0 8000 316.35626 0 56949.474 -2546.5963 -2673.901 127.30472 -409.10877 -1956.5929 256.64339 129.51615 129.15689 0 0
5 8000 -nan -nan -nan -nan -nan -nan -3.9170328 0 -nan -nan -nan 0 1.102758
How I could fix it!
regards
M
sjplimp
September 19, 2018, 12:32pm
#2
Your dynamics are bad. Print thermo info every step and see
what goes wrong first.
alberto
September 19, 2018, 2:32pm
#3
Hi steve,
In my input there is a group of molecules of DMSO.
Atom Groupings
END Atom Groupings
in output the code correctly, I think, the code finds
680 atoms in group DMSO
68 rigid bodies with 680 atoms
and I think that I could exclude intertions between atoms of some molecule with neigh_modify command with option exclude
regards
sjplimp
September 19, 2018, 7:27pm
#4
I just noticed you are applying 2 thermostats to your rigid atoms,
fix rigid//nvt/small and fix langevin. Not a good idea.
alberto
September 20, 2018, 9:10am
#5
I’m testing a small example defining 10 molecules of DMSO
I heve 10 groups, one for every molecule.
With rigid/nvt group 10 and ten groupID, the simulation is ok!
But I’m not increase the number of group > 32 as reported in manual.
How I could fix it?
Al
sjplimp
September 20, 2018, 1:09pm
#6
ok, now you are asking something different. The first
Q was about bad dynamics, which I think was due
to using 2 thermostats. You should not do that.
The 2nd Q is about how to use fix rigid. You don’t need
one group per molecule. Either fix rigid or fix rigid/small
will define one rigid body per molecule if you use the
right options. And you only need one group, no
matter how many molecules.
