Hello.
My simulation box has periodic boundary conditions in all three directions. I first use the SpatialBinningModifier
to coarse-grain the system into a three-dimensional grid of points, and then obtain the corresponding particle density values for each grid point.
There is a high-density region inside the box that I want to separate from other regions. I plan to use the CreateIsosurfaceModifier
to construct an interface between high and low densities.
The goal is to input a coordinate and determine whether it is located within the high-density region.
I know that the ConstructSurfaceModifier
can identify regions, so I wanted to ask if the CreateIsosurfaceModifier
can perform a similar operation? Alternatively, if there is a better solution in OVITO, I would appreciate your advice.
Thank you.
