Hi I want to download all data (4351 as shown in attached screenshot), with the properties, from battery explorer section. How can I proceed? What are the criteria that I should mention while querying such materials? Any help would be really appreciated
Hi Huta
Have you tried to use the new API?
Take a look at the documentation, I think the set of data you need is available through the /insertion_electrodes.
Maybe @munrojm can confirm that.
Thanks. But how do I use it with API? Can you please point out the nice documentation for this?
Please, have a look at Materials Project - API and the different links in there
Did you manage to get the dataset
Not yet. Do you have any idea about it?
Nope, I’ve also been traying but not getting anything
I also want to get that dataset. Has anyone got it now? Thanks
@Huta_Banjade @Mbabala @manojchh58 Please refer to our documentation: Getting Started | Materials Project Documentation. If you’re running into any issues, please include a short code snippet to reproduce it.
Thank you I got the data. Here is the code I used,
mpr = MPRester("your-api-key-here")
print(mpr.materials.insertion_electrodes.available_fields)
docs3 = mpr.materials.insertion_electrodes.search()
# then to get the data in pandas dataframe,
data = []
for doc in docs3:
row = {
"battery_id": doc.battery_id,
"battery_formula": doc.battery_formula,
"nelements": doc.nelements,
"working_ion": doc.working_ion,
"max_voltage_step": doc.max_voltage_step,
"average_voltage (V)": doc.average_voltage,
"max_delta_volume (%)": doc.max_delta_volume,
"capacity_grav (mAh/g)": doc.capacity_grav,
"capacity_vol (mAh/cc)": doc.capacity_vol,
"energy_grav (Wh/kg)": doc.energy_grav,
"energy_vol (Wh/l)": doc.energy_vol,
"stability_charge (MeV/atom)": doc.stability_charge,
"stability_discharge (MeV/atom)": doc.stability_discharge,
data.append(row)
# we can add any available features
# Creating a pandas DataFrame
df = pd.DataFrame(data)
# Displaying the DataFrame
print(df)
Thank you.
The data is now updated with more entries. If anyone needs help in getting the data please mention me. I will help. Thank you.
