I am new to using OPTIMADE, and I am trying to retrieve an entire database without applying filters. However, I am encountering a restriction that prevents me from downloading more than 1000 results at a time. The following warning is displayed:
Warning:
“Reached 1000 results for https://optimade.materialsproject.org/, exceeding max_results_per_provider parameter (1000). Stopping download.”
For my research, I need to download the complete dataset to compare it with our in-house database of compounds. When using the Materials Project API directly, I can retrieve the entire database, but this does not seem possible through OPTIMADE.
Is there a way to increase this limit or an alternative approach to obtaining the full dataset? Additionally, as someone new to OPTIMADE, I find the documentation somewhat challenging to follow. If anyone could recommend a good tutorial or share example code for querying and handling large datasets efficiently, I would greatly appreciate it.
Thank you for your guidance!
