Hi, All,
I am new to DPD simulation and have some simple questions to ask.
What I found is that when I use bond-style harmonic to define the spring force between beads with parameter 2.0 and 0.0, the bonded beads tend to overlap each other, i.e., the g of r has a peak close to zero. While non-bonded beads seem to have normal distance distribution with peak at close to 0.85. (with rou =3)
Even I change the harmonic bond parameters to 2.0 and 0.85, I still have a peak close to zero.
I use aii=aij=25 for every pair interactions.
Is it because that LAMMPS “possibly” neglects the repulsive pair-pair interaction when there is a bond between the pair of beads? The conservative force parameter (25) is much larger than bond force parameter (2*2, consider the later 2 is energy). If the conservative force is always considered, I don’t see a reason there is a peak close to zero.
Another question, how do I know that I am running a DPD simulation? Is the pair_style dpd definition enough to tell the program that I am running a DPD simulation? Should I specify the atom style also as dpd?
Thanks in advance for your help.
Best Regards,
Decai Yu
Hi, All,
peak close to zero.
Is it because that LAMMPS "possibly" neglects the repulsive pair-pair
please see the documentation about the special_bonds command and look
up the description of "1-2, 1-3 and 1-4 exclusions" in your preferred
text book on MD simulations. the default settings in LAMMPS are that
the special_bonds factors are 0.0 0.0 and 0.0.
don't see a reason there is a peak close to zero.
please see the documentation of pair style DPD and compare with the
quoted publications.
atom style dpd is part of the USER-DPD package, and only required when
using styles provided in that package. please see the file
src/USER-DPD/README and the corresponding sections in the
documentation for details.
Axel,
Thanks for your quick reply.
Does that mean if I don’t specify special bonds in the file, the factors are still 0.0, 0.0 and 0.0?
Decai
yes, that’s what default means.
Also note, as Axel said, that atom_style dpd is not needed
to use pair_style dpd. That atom style is only for the USER-DPD
package, which is not standard vanilla dpd.
Steve and Axel,
Thanks so much. You guys are awesome. That solved my problems.
I struggled for ten hours to ask the right questions.
Hopefully, this also helps other users of LAMMPS DPD.
Decai
