Dear Lammps Users,
I am using dpd thermostat along Lennard-Jones pair_style in a simulation in which I shear a system of particles with rough walls movements. I am willing to keep my temperature constant at 0.2 (LJ units) but this does not happens and what I do get is something fluctuating around 0.188. When I do use Nose-Hover Thermostat, this is kept fluctuating around 0.2. Temperature is an important parameter in my simulation, so I need it to keep it at 0.2.
I used the dissipative force constant of 1 as recommended by Soddemann et al ( PRE, 68 2003). I am using cut-off radius of 2.254 the same as my LJ pair_style.
I wonder if anyone have similar experience with dpd thermostat and have an idea how to fix this issue? I have also attached my input script.
Best regards.
Hassani
in.shear (2.88 KB)
Dear Lammps Users,
please note that an "exactly constant" temperature is only possible
with an infinitely large system. the instantaneous temperature will
*always* fluctuate. how much it fluctuates depends on the size of the
system. consider the extreme case of a single harmonic oscillator. its
temperature will fluctuate from 0K to 2xT, if T is the (average)
temperature.
pair_style.
this is a far too complex input to make a simple statement. all one
can say is that it looks to me that your way of determining the
temperature may be flawed. also, i don't think it is a good idea to
apply the dpd thermostat to particles that are time integrated via fix
move.
