I’m trying to simulate adsorption of ions onto a molecule, using OPLS-AA FF (by Moltemplate) in water SPC/E.
The results of density and temperature indicate good equilibration of the system.
When using npt, nvt, or nve modes, there is a constant drift of the whole system to the -x direction. I had seen drift with Langevin thermostat, but this is the first time, I noticed it when using Nosé–Hoover thermostat and barostat.
Has anyone had the same experience? Any suggested solution?
My input file is as follows.
Thanks so much
-X
Hi Xiaolin
Incidentally, I am not surprised you would see the system’s center-of-mass (COM) drift while using Langevin dynamics, however I would be surprised if it was drifting in a non-random way (for example, consistently moving in the -x direction).
Anyway, consistent movement of the COM in the -x directions sounds like the “Flying Ice Cube” phenomenon. It is most frequently associated with the Berendsen algorithm. However I am under the impression that other deterministic thermostats have “translational artifacts”. I’ve certainly seen very strange looking dynamics using Nosé-Hoover thermostat, especially when the simulation begins with the atoms arranged in a highly ordered, non-equilibrium manner.
Hence, if you prefer using Nosé-Hoover, have you tried equilibrating the system for a while using Langevin dynamics and then switch to Nosé-Hoover? Does that help?
Andrew
P.S. If you want to keep the center-of-mass of a group of atoms from moving or rotating, see:
http://lammps.sandia.gov/doc/fix_momentum.html
also see:
http://lammps.sandia.gov/doc/fix_recenter.html
Hi Xiaolin
Incidentally, I am not surprised you would see the system's
the "Flying Ice Cube" phenomenon. It is most frequently associated with the
deterministic thermostats have "translational artifacts". I've certainly
the drift doesn't originate so much in the thermostat, but rather from
the force computation.
certain factors enhance it:
- asymmetric/inhomogeneous system setup
- using floating point math with not very long cutoffs and without
force switching.
- velocity scaling thermostats like temp/rescale or berendsen
- imbalanced initial velocity distribution
- frequent switching between fractional, when the center of the system
is not also the origin
- running many rigid particles without excluding the internal non-bonded forces.
other factors dampen it:
- "noisy" thermostats like the various langevin variants
- removing and drift via fix momentum (but careful on systems with
non-periodic boundaries and immobile atoms where it can cause unwanted
artifacts)
