Dummy atoms in EMC
Hallo all,
Willling to use TIP7P with parameters from literature, I have to define dummy atoms in EMC. Up till now, I used unused letters (‘l’ or ‘m’), but the software says
‘No rule for type ‘l’.’
How do I define the dummy atoms? Thank you!
Following the instructions on TIP5P via
and the parameters in
DOI: 10.1021/acs.jpcb.9b03149
(Zhao et al., J Phys Chem B 123 (2019), 4594),
I could reconstruct the tip7p.mol:
Water molecule. Explicit TIP7P geometry for use with fix rigid
7 atoms
Coords
1 0.00000 0.00000 0.00000
2 0.75695 0.58588 0.00000
3 -0.75695 0.58588 0.00000
4 0.00000 -0.40415 0.57154
5 0.00000 -0.40415 -0.57154
6 0.37848 0.292940 0.000000
7 -0.37848 0.292940 0.000000
Types
1 1 # O
2 2 # H
3 2 # H
4 3 # L
5 3 # L
6 4 # M
7 4 # M
Charges
1 0.1110
2 0.5801
3 0.5801
4 -0.1772
5 -0.1772
6 -0.4584
7 -0.4584
… and the in.tip7p:
units real
atom_style charge
atom_modify map array
region box block 4.12 62.05 4.12 62.05 4.12 62.05
create_box 4 box
mass 1 15.9994
mass 2 1.008
mass 3 1.0e-100
mass 4 1.0e-100
pair_style lj/cut/coul/long 10.0
pair_coeff 1 1 0.150 3.156
pair_coeff 2 2 0.003 1.448
pair_coeff 3 3 0.0 1.0
pair_coeff 4 4 0.0 1.0
kspace_style pppm 1.0e-5
fix mol all property/atom mol ghost yes
molecule water tip7p.mol
create_atoms 0 random 33 34564 NULL mol water 25367 overlap 1.33
timestep 0.2
fix rigid all rigid/nvt/small molecule temp 300.0 300.0 10.0
velocity all create 300.0 5463576
thermo_style custom step temp press etotal pe ke
thermo 500
run 5000
write_data bunch_of_water_tip7p.data
