Dear Users,
I am using fix nvt/sphere integration scheme in my simulation of spherical colloid particles. As per the documentation it will perform constant NVT integration to update position, velocity, and angular velocity at each time step for finite-size spherical particles in the group using a Nose/Hoover temperature thermostat. So how can I dump this angular velocity obtained from the above integration scheme? Can I use normal ‘dump’ command options?
Thanks in Advance
