Thank you very much Carlos for your comment. You were right! The simulation was fine, just the way that temp was being dumped should be modified.
I've got also a bit of confusion about the way that dump/compute command work.
In my new input file, I am trying to compute and calculate mean squared displacement of fluid molecules during their diffusion through the rigid solid structure.
However, when trying to run MD, the simulation crashes with the following error:
"ERROR: Dump custom compute does not calculate per-atom vector (dump_custom.cpp:1165)"
Is there any other way of computing/dumping mean squared displacement that I should use instead? Here is also my input file:
