Hi Axel,
Thanks for your response. I have examined more on the problem which I
mentioned in my previous mail.I just want to redefine the problem:
I have seen that this 'binary' characters in the dump files are occurring
ONLY after I invoke the "tad ..." command.It does not depend upon the 'ensemble' description. I have attached a test
example (taken from LAMMPS distribution. I have only added two dump command.
One for the 'equillibration run and the other for the 'tad' part.) with this
mail.I have found that the dump file (dump.all in this case) for the
equilibration is of "ASCII:Text" character, but the dump file which
corresponds to the 'tad' part (dump.tad) contains the binary character in
the very first line itself.I have seen the same problem with other input files also consistently.
what version of LAMMPS do you use. i cannot
reproduce this behavior. i get text format output
in both cases.
[[email protected]... tad]$ file dump.*
dump.all: ASCII text
dump.tad: ASCII text
