sir,
i am getting an error in running following code(dump local)
compute 2 all property/local atype aatom1 aatom2 aatom3
compute 3 all property/local dtype datom1 datom2 datom3 datom4
compute 4 all property/local itype iatom1 iatom2 iatom3 iatom4
compute 5 all property/local batom1 batom2 btype
dump 11 all local 1000 tmp.dump index c_2 c_3 c_4 c_5
ERROR: Dump local compute does not calculate local vector (dump_local.cpp:303)
my input file(from VMD) contain following things
7872 atoms
11678 bonds
23098 angles
45729 dihedrals
7614 impropers
1 atom types
1 bond types
1 angle types
1 dihedral types
1 improper types
i have noted one thing in lammps manual
"Note that by using input from the compute property/local command with dump local, it is possible to generate information on bonds, angles, etc that can be cut and pasted directly into a data file read by
the read_data command"
i want to generate new read data file with angle , bonds etc. ...someone please help me with this error prolem.
Ragesh
sir,
this is not correct. each compute produces multiple properties
that have to be accessed with subscripts. also, you can collate
all compute property/local computes into a single one.
and this is the corresponding error message.
you have to re-read the lammps documentation more thoroughly.
7872 atoms
11678 bonds
23098 angles
45729 dihedrals
7614 impropers
1 atom types
1 bond types
1 angle types
1 dihedral types
1 improper types
why such a complicated path to produce a new data file?
why don't you use VMD scripting for that?
what is missing from your original data file?
