I find an very interesting issue when I using variable s equal logfreq(10, 3, 10)
after reading a restart file. Here is a snippet of my script:
read_restart an.restart
# forcefield settings
variable s equal logfreq(1,3,10)
dump 1 all atom 1 isf.dump
dump_modify 1 every v_s first yes
run 10000
but it only output the first frame not 1, 2, 3, 10, 20, 30 etc. I copied the snippet to an very simple script and it DOES take effect. Finally, I convert restart file to data and it works. So I want to ask if the dump_modify command or variable have any conflict with restart file? Or just I omit some details in the manual.
My LAMMPS version is LAMMPS (22 Aug 2018)
Here is my script:
# a restart script
read_restart 3000000.restart
neighbor 1.0 bin
neigh_modify one 10000 delay 1
variable eps index 1.5
variable di index 80
variable dstep equal logfreq(1,9,10)
dielectric ${di}
print "dielectric ${di}"
print "eps ${eps}"
pair_style lj/cut/coul/long 1.12246 10
pair_coeff * * 1.0 1.12
pair_coeff 2 2 ${eps} 1.0 2.5 # io-io
kspace_style pppm 1.0e-4
fix 1 all nve
fix 2 all langevin 1.0 1.0 100.0 699483
timestep 0.002
compute 1 all displace/atom
thermo 1000
thermo_style custom step temp density
dump 1 all custom 100 isf.dump id type x y z c_1[4]
dump_modify 1 every v_dstep first yes
run 1000000
Jichen Li
University of Science & Technology of China
