Hi all,
If I am running a simulation using a variable time step how can I dump files every 0.5ps rather than every n time steps?
Adam
Hi all,
Adam
Hi all,
please see the dump_modify every option, which can take a variable as an
argument. you will have to program a function that will provide an
extrapolation at what step the next dump should be when the current one is
performed. so it will be difficult to have it on exactly the desired steps.
LAMMPS needs to know at the beginning of a step that a dump is happening.
an alternative would be to use the every option to the run command to break
down a run into smaller chunks and then use write_dump with an if statement
dependent on the progress of time.
