I’m using the following command to dump particle velocity components in the dump file:
dump deform all custom 1000 deformation_T${T}_SR${erate}.lammpstrj id x y z type element vx vy vz
I would like to see if there is a way to output v (total velocity) in this command?
PS1: I understand that velocity has a direction and it might be physically inaccurate to report only the magnitude
PS2: The motivation behind this is to visualize the temperature “per atom” using the dump file and not an external post processing script.
PS3: I also understand that temperature per atom is not a thing, and that temperature and velocity are not exactly the same thing, however, for my specific system, I expect temperature and velocity per atom to behave similarly so that I can use one to visualize the other.
