Dear Lammps users,
I want to use eam/alloy potentials including Fe and Zr elements. Regarding the information on the Lammps page: ’ For style eam/alloy, potential values are read from a file that is in the DYNAMO multi-element setfl format, except that element names (Ni, Cu, etc) are added to one of the lines in the file. ', I wrote that
#EAM potential
pair_style eam/alloy
pair_coeff * * Fe.eam Zr.eam
However, when it starts to run, it always gives that :
‘ERROR: Incorrect args for pair coefficients (…/pair_eam.cpp:352)’
Do you know how it could be stated correctly in the input?
Thanks!
Regards,
Emel Gurbz
Dear Lammps users,
the information on the Lammps page: ' For style eam/alloy, potential values
#EAM potential
'ERROR: Incorrect args for pair coefficients (../pair_eam.cpp:352)'
such potential files are always specified as a *single* file. that is
for eam/alloy you have to download or construct a single file with all
terms for Fe, Zr and the mixed terms.
the files you are using are for the pair style eam, not eam/alloy.
please see the folder tools/eam_database for a code and parameters to
build such mixed potential files for some selected elements.
