eam for individual parameters in a mixture
Hello, i’ve a problem with the eam potential, i wish to built an alloy with Pd and Rh. i got their individual file parameters, but when i built a (.in) file, i don’t can run the simulation. Ever show me the same wrong “Failed to allocate -9758921144 bytes for array pair:rhor (…/memory.cpp:45)” and i don’t can understand what is the problem if i’ve built file more heavy. now i show you a piece of my input file.
read_data data.pdrh009
pair_style eam
pair_coeff 1 1 Pd_u3.eam
pair_coeff 2 2 Rh.lammps.eam
If somebody know, how built a input file, for two individuals compounds (we don’t have the parameters of a eam alloy only the individuals) please help me.
Hello, i've a problem with the eam potential, i wish to built an alloy with
file, i don't can run the simulation. Ever show me the same wrong "Failed to
allocate -9758921144 bytes for array pair:rhor (../memory.cpp:45)" and i
don't can understand what is the problem if i've built file more heavy. now
are you sure that both eam files are correctly formatted?
do they work for the individual pure systems?
