Hi everyone,
I am using the python library to fetch data from the insertion_electrodes endpoint.
for instance, I search for LiTiO2, lets look at the result with the battery id: mp-554278_Li.
I would like to be able to see whether ‘mp-554278_Li’ has any materials that were thermodynamically unstable. I thought I could look for that in the “electrode_object.unstable_entries” however the unstable entries listed there are not part of this result at all as they are not involved in any of the steps. Additionally, the materials found in “electrode_object.stable_entries” are also not stable.
when I looked up the documentation, I saw :
material_ids: List[MPID] = Field(
None,
description="The ids of all structures that matched to the present host lattice, regardless of stability. "
“The stable entries can be found in the adjacent pairs.”,
however adj_pair.id_char ( in this case ‘mp-554278’) and adj_pair.id_discharge(in this case ‘mp-1104112’) are also not both stable.
I would really like to know whether an insertionelectrode object is stable or not based on the materials it contains, I suppose I could recursively fetch every single material ID in the insertion electrode and check it for stability if nothing else is possible.
Thanks !
