Hi everybody,
I found the following description for the electron units in the LAMMPS doc.
For style electron, these are the units:
- mass = atomic mass units
- distance = Bohr
- time = femtoseconds
- energy = Hartrees
- velocity = Bohr/atomic time units [1.03275e-15 seconds]
- force = Hartrees*Bohr
- temperature = degrees K
- pressure = Pascals
- charge = multiple of electron charge (+1.0 is a proton)
- dipole moment = Debye
- electric field = volts/cm
I assume that there is a typo in the force units (It should be Hartrees/Bohr, I think) but what I don’t understand is
where the “1.03275e-15 seconds” comes from since 1 atomic time unit is 2.418842605e-17 seconds.
Is the time unit really 1 femtosecond?
Thank you for all your work.
Cheers.
Pablo.
---------------------------- Confidencialidad: Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario y puede contener informaci�n privilegiada o confidencial. Si no es vd. el destinatario indicado, queda notificado de que la utilizaci�n, divulgaci�n y/o copia sin autorizaci�n est� prohibida en virtud de la legislaci�n vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente respondiendo al mensaje y proceda a su destrucci�n. Disclaimer: This message and its attached files is intended exclusively for its recipients and may contain confidential information. If you received this e-mail in error you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited and may be unlawful. In this case, please notify us by a reply and delete this email and its contents immediately. ----------------------------
