I found the fix, I didn’t add a bond from PHB to PHV.
To make 5 chains of 150 monomers each:
in the options section, you take out ntotal and put number = true, for the number 5 (chains) in cluster to take. Then you have the 150 after describing the weights in the poly section.
Cudos for finding the solution on your own. You were two seconds before me. Indeed, you did forget a connection. The full .esh file in scrollable textual form you find below. You can accomplish this yourself by starting and ending your code snippet by three single back quotes ```. This way, people can actually copy the problem (and of course the solution) to help you more quickly. Please be aware, that when you are interested in polymer properties, you would be advised to have at least 100 polymer molecules in your simulation. I also noticed, that you did not specify any density. I would assume, that the actual density of your polymer at T = 300K is not 1 g/cc. The density for e.g. polylactic acid is 1.2 - 1.4 g/cc.
#!/usr/bin/env emc_setup.pl
# Options section
ITEM OPTIONS
field pcff
field_increment warn
#field_debug reduced
density 1.3
mass true
replace true
number true
emc_execute true
ITEM END # OPTIONS
# Groups section
ITEM GROUPS
PHB *CC(=O)OC(*)C,1,PHB:2,1,PHV:2
PHV *CC(=O)OC(*)CC,1,PHV:2,1,PHB:2
methyl *C,1,PHB:1,1,PHB:2,1,PHV:1,1,PHV:2
ITEM END # GROUPS
# Clusters section
ITEM CLUSTERS
poly random,100
ITEM END # CLUSTERS
# Polymers
# Polymers section
ITEM POLYMERS
poly
1 PHB:PHV=6:4,150,methyl,2
ITEM END # POLYMERS
