I am trying to simulate lennard jones gas and made several runs. The log file in my directory is empty. I am just using **in file. I think I do not need to use any potential files because it is a lennard jones gas and fluid. Any help appreciated?
Can you run bench/in.lj and get a log.lammps file, either
on 1 proc or multiple procs?
file i/o is block buffered, so there will not be any output unless you
have at least a block's worth of pending i/o (usually 4kB or 8kB) or the
file is ordinarily closed. please note, that you should also have output to
the console, if you use the default settings.
with out more details about what you are doing and how, it is difficult to
give more specific advice. how LAMMPS handles i/o is also explained in the
documentation.
If this is the problem, there is a thermo_modify flush yes
command that forces output to the log file
every timestep that thermo output in invoked. If your simulation
gets as far as the initial (time 0) timestep, the output should
then be in the log file.
