Apologies for bumping an old post, but I’m interested in knowing how to calculate the e_above_hull using my own DFT-calculated data.
Below is the code I used, and following that, the error message that I received.
from pymatgen.ext.matproj import MPRester
from pymatgen.analysis.phase_diagram import PhaseDiagram, PDPlotter, CompoundPhaseDiagram
from pymatgen.entries.computed_entries import ComputedEntry
from pymatgen.core import Composition
# from pymatgen.analysis.pourbaix_diagram import PourbaixDiagram, PourbaixEntry, PourbaixAnalyzer # StableEntry
# from pymatgen.analysis.phase_diagram import PhaseDiagram, PDAnalyzer, ConvexHullAnalyzer
# from pymatgen.analysis.pour import ConvexHullAnalyzer
# Assuming you have a list of computed entries (e.g., from a database)
entries = [
ComputedEntry(Composition("Y4N4"), -164.774553),
ComputedEntry(Composition("Y16Ti16O56"), -1377.12118691),
ComputedEntry(Composition("Y8Ti4O20"), -532.80516856),
ComputedEntry(Composition("Y4Ti4O8N4"), -322.86938277),
ComputedEntry(Composition("Y2"), -55.73665798),
ComputedEntry(Composition("N8"), -74.18410792),
ComputedEntry(Composition("O6"), -36.28556130),
ComputedEntry(Composition("Ti3"), -48.18069328),
] # List of entries with structure and energy
pd = PhaseDiagram(entries)
# Create a ConvexHullAnalyzer
# hull_analyzer = ConvexHullAnalyzer(entries)
# For a specific compound, e.g., La2Ti2O7
compound = Composition("Y4Ti4O8N4")
energy_above_hull = pd.get_e_above_hull(compound)
print(f"Energy above hull for {compound}: {energy_above_hull:.4f} eV")
And this is the error that I get:
/usr/local/lib/python3.10/dist-packages/pymatgen/analysis/phase_diagram.py in get_decomp_and_e_above_hull(self, entry, allow_negative, check_stable, on_error)
758 except Exception as exc:
759 if on_error == "raise":
--> 760 raise ValueError(f"Unable to get decomposition for {entry}") from exc
761 if on_error == "warn":
762 warnings.warn(f"Unable to get decomposition for {entry}, encountered {exc}")
ValueError: Unable to get decomposition for Y4 Ti4 O8 N4
I have several questions regarding this code and the science/equations behind formation energy, decomposition energy and energy above hull. I am inexperienced in both Python codes and materials thermodynamic stabilities, so forgive me if the questions are somewhat vague or confusing.
Is there a way I can modify this code to make this work? Should I include more reference structures? What other calculations am I missing in order to calculate the energy above hull?
What does the equation of energy above hull looks like, and how does it differ with the equation of formation energy?
Thank you for your time!
Edit 1:
I managed to fix the error by modifying a certain part of the code into this:
compound = ComputedEntry(Composition("Y4Ti4O8N4"), -322.86938277)
But now I get this input, and I am unsure on how to interpret it. Is it saying that the material is on the convex hull, or am I using the wrong reference materials which results into this?
Available compositions in entries:
Y4 N4
Y16 Ti16 O56
Y8 Ti4 O20
Y4 Ti4 O8 N4
Y2
N8
O6
Ti3
Energy above hull for None ComputedEntry - Y4 Ti4 N4 O8 (YTiNO2)
Energy (Uncorrected) = -322.8694 eV (-16.1435 eV/atom)
Correction = 0.0000 eV (0.0000 eV/atom)
Energy (Final) = -322.8694 eV (-16.1435 eV/atom)
Energy Adjustments:
None
Parameters:
Data:: 0.0000 eV
